alankulwicki7
So I finally got a pressure pot the other day and put it to use last night. I tried to follow the advice from other posts and the library but my castings came up well short of my expectations.
I started out by gluing some fabric to the tubes using CA. Then I put some nails in the tubes for weight, added a little play-doh at each end and then made some blocks out of maple to hold the tubes in the center of the molds. Then I gently filled the molds with some PR and put them in my pressure pot at 45psi.
This morning when I went to check on the castings there were some small bubbles in one area of the fabric. I think this might be because the CA was not thoroughly dry and was still off-gassing.
The other problem I had was that the resin ended up compacting enough so the top of my item was barely under the resin.
When I filled the mold with resin, I made sure that it was full (and almost over flowing. Any advice as to why the resin came up short in the mold?
PS I'm hoping to get this right because I want to enter the casting contest this year!
