avbill
I have several wood and alumite fill blanks turned and ready for finishing I have sanded and started with straight CA The wood part of the pen blank is taking the CA with no problems. It's the alumite that is becomes sticky never drys -- Even after 30 minutes the ca tends to dry only to a grit form There is no sanding grit on the blank I use air pressure to clean the blank. then use alcohol for a clean finish. i wait for 15 minutes before applying the CA
I continue to re-sand the blank down and start over again. getting the same results. what are to people finishing the combo wood and alumite with?
Am I missing something.
bill
bill
