dabeeler
I recently made a pencil and pen finishing with CA over shellac. I applied the shellac, made from dewaxed flakes and about a 2lb cut or so cut, and brought up a high gloss polish by adding a drop of BLO to the shellac which was then applied with the blank spinning in the lathe. The friction brought up a very deep high gloss shine that felt very smooth and got very hot as it does when applying CA/BLO. I then applied four coats of CA (medium) and BLO to create a durable top coat. This was taken from the lathe to the Beal Buffer and processed with Tripolee, White Diamond and Ren Wax, the result of which really looked good. One blank was Bubinga and the other Purpleheart.
Now the problem. I have been using the Bubinga pencil and almost immediately it began to show dull spots under the finish on the lower barrel which have grown in size and are very noticeable. These dull areas appear to be under the CA finish. The Purpleheart pen which has not been used has not developed any dull spots as of yet. Both were done last weekend.
Any theories on what is happening here?
David
David
