Drill press speed for pen blanks?
sbwertz
Phoenix, AZ
What speed should I be running my drill press to drill wooden pen blanks with a 7mm bit?
The chart on my drill press says 2400 RPM for a 1/4" bit in hardwood, but it seems MUCH too fast. It screams when I drill at that speed. I've been drilling at 1500 RPM and it still seems too fast.
When drilling on the lathe I run it in it's slowest speed...about 600 rpm.
PenMan1
Eatonton, Georgia
Sharon:
On the DP I like to use between 800 and 1100 rpms. That works very nicely for wood. With acrylic, pr, et al, I make a center punch "dot" and drill about 1500 rpms.
randyrls
Harrisburg, PA 17112
Sharon; Yes; 2400 is tooo fast. 600 to 1000 is about right.
I don't like to use brad point bits because they are hard to sharpen. It is important to have a sharp drill bit. I sharpen mine whenever I notice that I have to press harder while drilling.
On acrylics, cut the blank over long, drill the hole just the length of the brass tube, cut off the excess.
brez
Pilot Point, Texas, USA
Sharon,
I drill at 600 rpm. It is slower but it does not build up a much heat and cracking blanks are a rarity. Also be sure to pull out and clean the bit freguently.
Mike
sbwertz
Phoenix, AZ
Well, it is a brad point bit right now. First time it goes through the drill doctor it won't be any more LOL.
I pull out about every quarter inch. I have no problems with blowout or blanks shattering in the vise, but it squeals at this speed. I will slow it down.
I bought one of the colt bits, but have a problem with it deflecting on entry in any wood with a strong grain. It will deflect about a 32nd of an inch, following the grain. It is a brand new 7mm bit, longer than my other bits. When I withdraw it, I can see it flex to the side as it comes out of the blank. It results in an oval entry hole and is off center at the bottom. I don't have that problem with my shorter brad point.
Thanks for all the input.
KenV
Juneau, Alaska.
Two measures -- successful outcomes and comfort for the operator. I find that given similar outcomes from the first, the second wins most all the time.
One of the diamond "credit card" sharpeners can keep a brad point bit sharp for a long time -- then the drill doctor.
Side note -- Drill Doctors are good for general bit sharpening, but are not a high precision tool grinder -- I send the special (large sizes used for fancy stuff) out to a tool and die guy for sharpening. Same with end mills.
Hope to see you at the Desert Wood Turning Roundup --
fernhills
Hellertown, PA, USA.
Is that chart, not for bit size, but for thickness of material ?
jedgerton
Austin, TX, USA.
800 rpm for me. Seems to work well. BTW I purchased a 7mm pen turners bit from Woodcraft 4 years ago. It's never been sharpened and it's still working fine! Your mileage may vary.
John
Mark
Pottstown PA
I drill at 600 rpm for most all materials. I love the Wood River bits from WC.
I bought a set of the Colt and ended up packing them up and storing them. They are much longer which was nice, but I too, found they would deflect when drilling hardwood and acrylics. I am not happy with them at all...
Just my $.02
LeeR
Fort Collins, Colorado
With pen blanks, or most any piece of wood I'm drilling. I use a "backer board" -- usually a thin piece of plywood scrap, under the piece to be drilled. No blowouts, and no edge tearing. I've only drilled a few acrylic blanks so far, but I've used the same technique, and had nice clean drilling. I back out of the hole often, and I also have a shop vac running to suck up the drill debris.
Sort of off topic, but use a small square to periodically check to make sure your DP table is perpendicular to the bit. They can get jarred easily, and a couple degrees can cause a real problem when trying to get really straight bores.
