Drill bit stops
monophoto
Saratoga Springs, NY
From time to time, we are all faced with the problem of drilling to a known depth. Yes you can buy drill bit stops that attach to a bit using a grub screw. Unfortunately, the set I bought from Harbor Freight are nearly useless - it comes with a small Allen wrench that is supposed to fit into the hex socket in the grub screws, but in fact it doesn't.
Alternatively, there is also the trick of adding a masking tape 'flag' on the bit to mark the desired depth.
But here's another idea - cut a slice from one of those plastic wine corks that are now used in a lot of less-expensive wines. Drill an on-axis hole (it doesn't have to be exactly on-axis - close is fine) in the slice that is slightly smaller than the bit it will be used with (eg, for a 1/4" bit, I drill a 7/32" hole). Slip this over the bit, and there you have it - a stop that will slide along the length of the bit, but that fits snugly enough that it won't move unless you really want it to.
Herb G
Southern Maryland
I guess I'm lucky. My drill press has a built in depth gauge good up to 6".
When I was working full time, we used 2" wide duct tape & made a flap
by overlaying the tape on the drill bit. When the bit hit the marked depth, the flap would stop turning.
magpens
Canada
I know the problem ... I feel your pain !
But from my experience, you can't beat a narrow band of masking tape around the bit.
The other suggestions, which I have tried, are usually too cumbersome and big for my requirements.
TonyL
Georgia
Rick Herrell sells tool rest collar stops. Maybe they can be used as drill stops?
dogcatcher
TX, NM or on the road
I make my own out of cutoffs. I drill the bit size hole through the center, then cross drill and tap those holes for 1/4" set screws. If it is a drill bit that I will use quite a bit, I buy an extra bit and make it a permanent set up and add it to my custom bit storage.
