Drill Bit sizes
johnjr
South Carolina
So I've ordered one of the PSI Nouveau Sceptre Pens with the starter kit, but I'm not sure I want to try drilling with the "normal" drill bits that come with it - I'd be much more comfortable with a brad point. The problem I'm running into is I can not find a 10.5 mm or a 12.5 mm drill bit anywhere, and I'm not having great luck with a fractional equivalent. Could I go slightly oversized and then use Gorilla Glue to put the tubes in to fill the gap?
Rifleman1776
Mountain Home, Arkansas, USA.
Hmmmm, maybe I should wait to ask my questions until I actually get the order in......
Yes, that would be wise.
As an alternative.....a good one, actually.....sharpening twist bits on a Drill Doctor then giving them a split point makes an excellent blank drilling bit. Personally, I prefer brad points but the splits are very good.
My advice is to stick with the sizes reccomended by the vendor. So called 'gap filling' is unacceptable in my view.
hewunch
Albany, GA
Well the brad point bits I got with the FS Majestic were not too great. My twist bits ran rings around them (no pun intended)
