jzerger
Since I realized, from experience, that at least one of the tubes needs to be shortened to make the refill stick out far enough to make it "look" like a pen, I'm attempting to disassemble the ones I already finished. The white plastic clicker mechanism is pressed into the upper end (held in by the clip) and the other end has the recessed coupler. The two barrels are pressed together with the center band piece. I need to separate the barrels or get the clip off from the outside...any ideas?
