Delta Hollow Chisel Mortiser
Bean_Counter
Lubbock, TX
Hey guys I've had this machine for about 4 years and have never used it. I bought it used but used once. I will likely never use it as I just bought a domino. It comes with the chisels which are all still sharp. I'd like to get $225 for it but would have to a pickup OR if you are going to the Houston wood working show at the end of the month I might can deliver if you are on the way from Lubbock. Some rust on the table but I'll clean it up and wax it. I also have the tenon jig for the table saw and would like 50$ for it.
It is always ashame when people put photos on here that are sideways. I wish there was a way to be able to rotate these photos easily without having to download into another file. Isn't there a command on the key board you can use to rotate a photo??? All your computer guys.
I have this mortiser also and have used it many times. I will be incorporating its use into some segmented pens in the future. Good price if coming with the bits.
