Hi Chuck... the krylon crystal clear is a protective coating for almost any application. It does not consider what is underneath but is used as an overcoat.
From Testors instructions:
[FONT=MyriadMM_565_wt_600_wd]
[FONT=MyriadMM_565_wt_600_wd]Bonding:[/FONT][/FONT]
[/FONT][FONT=MyriadMM_400_wt_600_wd]
[FONT=MyriadMM_400_wt_600_wd]1. After the ink has had a chance to dry, you need to apply a coat of Decal Bonder over[/FONT][/FONT]
[FONT=MyriadMM_400_wt_600_wd]the top of the ink to bond the inks together. This holds the inks together when[/FONT]
[FONT=MyriadMM_400_wt_600_wd]sliding off of the backing paper. Shake Decal Bonder vigorously before using and[/FONT]
[FONT=MyriadMM_400_wt_600_wd]reshake frequently. Avoid spraying when humidity is high.[/FONT]
[FONT=MyriadMM_400_wt_600_wd]2. Spray a light coating over printed decals; do not apply too much Bonder as this may[/FONT]
[FONT=MyriadMM_400_wt_600_wd]cause unwanted results when Decals are applied over complex surfaces.[/FONT]
[FONT=MyriadMM_400_wt_600_wd]3. Allow 2 hours dry time.[/FONT]
[/FONT][FONT=MyriadMM_565_wt_600_wd]
[FONT=MyriadMM_565_wt_600_wd]Not looking for any arguments. Maybe I read this wrong.[/FONT][/FONT]
[/FONT]
