csuas filagree bushings help
drayman
barnsley
hiya guys, does anyone know the sizes for this penkit bushings in mm.
the bushings are 1b set but i need the measurements. thanks in advance.
sorry guys its arizona silhouette filligree and not csusa.
ssajn
Local Chapter Leader
Milwaukee, Wi, USA.
Hi Colin,
Sorry, don't know the measurements your looking for but you should be able to measure right off your pen parts and even make your own bushing from those measurements. I've started making all my own bushings. Another option would be turn without bushings.
Hope this helps.
Dave
ed4copies
Local Chapter Manager
Racine, WI, USA.
This filigree is a "special case". Usually, you turn and allow a little for sanding to keep your OD at a nice, smooth with the fittings level.
With the filigree, the material needs to be turned to a slightly undersize diameter. Realize the wood will swell some, over time, and the filigree will not.
Just a FWIW!!
