I've been fighting with a CA finish since last night.
I started with BLO and thin CA then finished with One-Step Plastic Polish and at first glance it looked fine. A close look showed very minor scratches in the finish and I was sure it was in the CA, not the wood.
I just picked up some Novus plastic polish - never used it before so I thought I would try it. It took the CA down to a flat finish and I thought at first I had gone to the bare wood. However when I buffed back up to the the One-Step Plastic Polish and it was 80% excellent - no micro scratches - high glass - but 20% had no CA left.
I surface cleaned it and reapplied CA, WITHOUT sanding it all back to bare wood. Micromeshed it all again and this time its 99% good except for one small area, that is not high gloss. About to hit my head against the will, but I surface cleaned it again, and zapped some more CA on and walked out of the workshop
Even if it works this time, I wonder it the finish will be good, with all the reworking, adding different polishes - maybe I ended up leaving contaminants that will react later.
When do you give up on CA, and just sand it all away and start from scratch?
