Blank cutting drill bits
jason_r
Chandler, AZ, USA.
I'm looking for the drill bits that drill a round blank out of a board while simultaneously drilling the center hole.
I've seen these before, but can't seem to find them on PSI, Woodcraft, or Craft supply USA's site, and can't remember the specific name to search for.
Have these gone the way of the dodo or what search should I plug in to find them? (or anyone have a link?)
NewLondon88
Local Chapter Leader
Claremont NH
are you talking about a plug cutter? I've never seen one long enough
for a pen blank, but who knows.. they might make them.
But where's the fun in that?
Haynie
Page Arizona
That would be one monster long hole saw. I have a set that you can change out the guide bit but it won't take one as wide as most pen sized bits.
jason_r
Chandler, AZ, USA.
Not exactly a plug cutter, but that's not a bad comparison. This is a drill bit that would do one barrel of a pen blank at time- so about 2" long, with open sides and a regular twist drill down the center. So it's cutting 2 concentric circles- the hole down the center and rounding the outside at the same time.
Where's the fun in that? I have an idea where I need rounded blanks with the center hole drilled. It's just an intermediate step, not a finished pen.
Are you talking about something specifically for pen turning? A keyhole bit does that but it would not do a pen blank.
Yes, this is specifically for pen turning. I can picture the ad page showing a piece of ?Padauk with a series of blanks drilled, with the bottom edge still attached. Just can't find it or remember the right name.
NewLondon88
Claremont NH
sorta like a hole saw or plug cutter with a drill bit in the middle.
Wonder if they make them with changeable bits?
jfoh
Some one gave me one of those several years ago. I had a problem with the drill not staying in the center of the blank. It would drift to one side. Perhaps you will have better luck.
JF36
Pen Argyl, PA
It looks like any bit can be used as long as it has a 7mm shank on it. If you had a metal lathe to could take any short drill bit that has a shank larger then 7mm and turn it down to 7mm to fit the cutter.
robutacion
Australia - SA Adelaide Hills
Yes, that would be the way to get any drill size working with these cutters.
I haven't seen them before and I'm amazed on how they could be handy in many situations, looking at the complete kit price, it is a great saving at $119.05 compared with the 142.20 of buying it separately...!
Great link, thanks...!
Cheers
George
witz1976
Bucksport, Maine, USA
jason_r
Chandler, AZ, USA.
I have access to a metal lathe. :biggrin:
Not that long ago I had to shave my 33/64 drill bit down a scosch so it would fit my 1/2" chuck.
