crokett
Here are the assembly instructions:
http://www2.woodcraft.com/PDF/77C05.pdf
I am stuck on second page, upper barrel assembly where it says
"Upper Barrel (cap):
Slide the Black Trim Ring (J) onto the Center Ring (I), followed
by the Gold Trim Ring (K). Slide the smaller diameter of the Cap
Thread Tube (L) into the Center Ring/Trim Rings. Press this
assembly into one end of the shorter tube. Slide the Top Finial (O)
through the Clip (N) and press this assembly into the other end of
the cap tube."
My problem is what is in bold. If I do that. then I can't screw the cap on. On part L the threads are in the narrow end, the end you slide into the trim ring. When you do that the unthreaded end is sticking out and it is too small to go over the threads. Has anyone assembled one of these kits? Did I get the wrong part?
the cap tube."
