fisherhahn
I've been making some antler/30.06 bullet pens and have been crushing numerous actions when trying to assemble them. I can't for the life of me figure out why. I've been using standard 7mm tube form PSI, cut to length and soldered into the rifle shell. I'm making sure there is NO glue or solder inside the tubes. I have even been sanding the crap out of the inside of the tube to try to get an easier fit when pressing together. The last couple times I also tried hitting the brass end of the action on my buffing wheel to polish it up for a smoother fit and the actions still keep sticking and then buckling. I had put together 100's of other 7mm pens and never had this problem. I was thinking maybe bad tubes from PSI, but they fit the mandrel and mill just the same as any others. I'm stumped. Any suggestions?
