Another drill bit question
Xander
Arizona
I don't know why people insist on having these (expensive) metric drills. Get a good set of regular drill bits, measure the tubes, and use the appropriate bit. The set I have came from Harbor Freight, contains all bits from 1/16 to 1/2 (by 1/16ths) and was quite reasonably priced.
skamrath1
Duncan, Oklahoma
Well with being so new to pen turning I don't know all the in's and out's, what can or can't be substituted. I am just going by suggestion on websites!
Monty
Group Buy Coordinator
Pearland, Texas, USA.
I assume this is in metric? I would urge you to *NOT* purchase single bits as they are more expensive than a full set of bits. You can get the 115p set, full letters, full numbers 1/16 to 1/2" and a caliper, you will be set for a good number of years.
115 Piece High Speed Drill Bit Set w/ Drill Index Not bad for $35.99
Thanks I am going there today to get these
If you have a HF close to you, then there is probably a 20% off coupon in today's paper. Take that with you.
Jim Burr
Banned
Reno, Nv
Colt's brad points are Big $$ IMHO. I use regular twist bits and drill on the lathe. I find "center" by crossing corner to corner and then use a spring loaded punch to mark. This way I can use the less expensive bits. I Googled it and didn't see that they make 10.5 or 12.5 Colts.
This link will help you find fractionals...if there is one!
Drill Bit Size Chart
mredburn
IAP Activities Manager
Staff member
Fort Myers FL
First of all there is a reference in the library that shows the number and letter and metric and fractional drill bits. I keep a copy of it printed out and on my desktop. http://content.penturners.org/library/general_reference/conversions.pdf
It will help you decide which drill bit is closest to what your looking for
A 10.5mm Drill bit is slightly smaller than 27/64ths and larger than 13/32. Most 10.5 tubes will fit in the 10/32 hole easily. Then the 12.5 is under 1/2 and over 31/64
All most all tubes are undersized from the size specified. Check them with a digital or analog caliper. If your going to use the drill sets for other things than pen making by all means buy a full set. If all your going to use them for is pens than buy only the ones you need. Or do like I do and buy every last one known to man.:biggrin:
