3 problems & a home run
Arkansas
On a previous post I showed this box elder blank that was not concentric with the tube. After advice from more experience turners, I discover 3 problems: 1) Tailstock was not aligned with head stock, 2) I was not drilling perpendicular hole thru the blank, & 3) I was over tightening the brass nut & the tailstock. After addressing all this misalignment, I was able to salvage the piece and mount in a WallStreet Titan.
its_virgil
Wichita Falls, TX, USA.
1 and 3 were the causes of your OOR pen barrels. #2 had little effect, if any, on the roundness of your pen barrel. Glad you got it fixed.
Do a good turn daily!
Don
Dale Allen
Massillon, OH
The 'logic' term was used in reference to the process, not the person.
No other reference was intended and none should be taken.
Lighten up virgil!:biggrin:
