glycerine
Has anyone used the Mandrel Saver tailstock from PSI? It's basically a tailstock with a hole drilled all the way through the center. So instead of putting the brass nut on the end of your mandrel and tightening it against your bushings, when you slide the tailstock up, the mandrel goes right through the center and the tailstock itself touches the bushings. Looks very interesting, almost like turning between centers, but you can do the cap and body at the same time. No pressure is put on the mandrel itself when tightening everything up...
I'd like to get opinions if anyone has tried it, or if you think it's worth me trying. They're only $14.95.
