Dismantling Jnr Emperor Clip.
TurnaPen
Trinity Beach, Queensland, Australia.
I am trying for a closed end Jnr. Emperor with invisible clip, here is how I pulled the clip apart.. Amos
Pictures 1 &2 the clip as is.
pic 3-the three step hole so I could punch out the cap.
pic 4 -the clip in the hole use a thin rod and punch out, pic 5 the end cap out
pic 6 -now a small gap appears on the clip.
pic 7 another jig close to the end of the block a 12.5 mil hole place clip in it. Pic 8 you can see small brass ring within the silver ring
pic 9 I used the end of a 5/16 drill bit and ablock of wood to punch out the brass bit
pic 10 all apart, pic 11 all apart, pic 12 all apart
pic 13 all apart close up, pic 14 all apart close up
pic 15 just to get this!!! and pic 16 and this!!
Amos
GouletPens
Ashland, VA
Well hot damn, I've never seen anyone disassemble that clip! I need to spend more time on IAP:wink: Very well done, thank you for the step-by-step pics. I've always been ticked that the finial is NEVER aligned straight with the clip and it's bothered the crap out of me, I never even thought to dismantle it and rebuild it! I'm guessing the whole thing is glued together, not just press-fit, am I right?
cnirenberg
Fort Myers, Fl
Amos, well done indeed. Now you must post a photo essay on your sweet invisible clips. You gotta know that was coming. Thanks for posting this.
TurnaPen
Reason why I haven't posted on the "Invisible clips" is because there are two excellent articles in the library on it; but I will photo this time around and maybe put in this section,(beware) I use the laser to cut the clip hole. Amos
glycerine
Fayetteville, NC
Man, you must have more money than me... that's like buying a Ferarri and pulling out the engine! Ok, maybe I'm exaggerating a little.
Good work, let us know how it turns out.
bracky1
Scotland
Filed away for future reference :)
Thanks for having the gonads to do this and double thanks for taking the time to photograph and post.
GouletPens
Ashland, VA
Not all's a waste...you could always use the finial to embellish another pen...
It has my gears turning now. I'm thinking of dismantling a JS2 and making a custom finial for it.
Dai Sensei
Gold Coast Queensland Australia
I must admot I'm still a bit confused about how to grind down the clip, when with this type of clip the dia of the "ring" part is close to the outside dia of the pen - ie how do you gind it down without grinding it away?
Cheers
VisExp
Palm Coast, FL, USA.
That has to be a bit nerve wracking pounding on that clip!
Amos, would you mind if I copied your images and explanation and prepared a short article for the library?
