PSI casting kit
ryankelley
chicago
I am new to pen turning and was looking through the PSI catalog. Is this kit any good, do I new a press. or vac pot? what are your opinions on this kit?
rdunn12
Gardendale, AL, USA.
Well,it is ok.It is 39.95+shipping.You could go to U.S. Composites and get a gallon of Silmar 41 for 34.50 and the pigment sampler pack for 35.00 (I have it,plenty of colors) and find some Tupperware for molds or make some from cutting boards.I believe there is a post about that.You would have a lot more resin to play with.If you are not planning on embedding anything,just doing simple casts,you do not need a pressure pot.Casting is a lot of fun.You will be out of that 32oz can in no time.The link will take you to the website I mentioned.
http://www.uscomposites.com/polyesters.html
mrcook4570
Mason, WV, USA.
The PSI kit is good to see if casting is something you want to do without dropping too much money. You can also go to Michael's or other similar hobby store and find casting supplies priced about the same as PSI. If you find that you like casting, then definitely buy it by the gallon.
Nick
Lakewood, WA, USA.
Ronald, or anyone, what method do you use to assemble the "cutting board" molds?
its_virgil
Wichita Falls, TX, USA.
Embedding: like snake skins, labels, circuit boards, or other stuff wrapped around the tube and embedded in some type of resin. For me the choice is polyester resin and others use Alumilite.
Do a good turn daily!
Don
Sorry for this stupid question, what do you mean by embedding?
rjwolfe3
Mansfield, Ohio, USA.
I believe (and I am no expert) that most of the snakeskin are done on the thicker kits. Of course I could be wrong, I just haven't seen a slimline snakeskin yet, lol.
rdunn12
I just put them together with drywall screws.I assemble them with drywall srews and then use aluminum tape on the outside to seal them up.I think I read somewhere that someone uses clear silicon to seal the mold but not sure.You will get some seapage through the joints using the tape method,(it won't go through the tape)but after the first use let it dry a while and the resin will seal it up.Works for me.Cheap too.
its_virgil
I make my snakeskin blanks for most of the kits. My favorite is the Sierra (not the sierra vista), the baron, and cigar. In addition to the ones mentioned, I've made blanks for the elagant beauty, jr gent and statesman, gent and statesman, the 7mm euro, slimlines, patriot, zen, and probably others I've forgotten. A 7mm euro was posted last week by alex Chapa from a set of blanks I made. I do make slimlines but I don't (personally) like snake skin on the top and bottom, so here is how I do slimlines.
The skins on these rattlesnakes are not tissue paper thin but they are not super thic either. I very seldom cut into the skin and if I do it is usually on the end of a sierra. I've wanted to try the sierra vista but I don't really have problems with the sierra. I don't remember the last skin I cut into.
Don
