polyurethane flammable?
Elliott
Canada.
Hi,
I have switch my finished from CA to Min Wax PolyU, but I was wondering if this stuff is flammable. Specially the fumes. I saw one site that said the Liquid is, but not the fumes, and another site that just said Poly U is flammable - with no mention of the fumes.
I work near my gas furnace and water heater so I would rather not start a fire when the pilot light goes on. Does anyone have any exipiance or know about this sort of thing?
Thanks,
Elliott
marcruby
Warren, Michigan, USA.
I've included part of the Material Safety sheet fo MWPU. While it' all perfectly true I don't think a single pen or two present much of a danger.
Marc
Fire and Explosion Hazard Data
Flash Point: >101F
Flash Point Method: SCC
Extinguishing Media: WATER SPRAY, FOAM, DRY CHEMICAL/CO2.
Special Fire Fighting Proc: DON'T USE A DIRECT STREAM OF WATER. WEAR SCBA
& PROTECTIVE CLOTHING. USE WATER SPRAY TO COOL FIRE EXPOSED CONTAINERS.
Unusual Fire And Expl Hazrds: COMBUSTIBLE. PRODUCT MAY FLOAT & CAN BE
IGNITED ON SURFACE OF WATER. CONTAINERS EXPOSED TO INTENSE HEAT MAY
RUPTURE.
Reactivity Data
Stability: YES
Cond To Avoid (Stability): HEAT, SPARKS, OPEN FLAME & OTHER SOURCES OF
IGNITION.
Materials To Avoid: STRONG OXIDIZING AGENTS.
Hazardous Decomp Products: HYDROCARBON FUMES, SMOKE, CO.
Hazardous Poly Occur: NO
Hi,
Thanks,
Elliott
A liquid must vaporize before it becomes flammable... even wood actually reaches a vapor point befor it burns... that said, unless you spray PolyU into the air and probably directly towards an open flame, no more than you would use on a pen, I would think you are safe...
redfishsc
North Charleston , SC
You will be fine, especially if working with only a gallon or a quart of finish. The tiny amount of evaporated solvent isn't enough to cause a flash, so long (as said above) you aren't spraying the stuff.
RussFairfield
Passed Away 2011
Post Falls, Idaho.
Everyone has always told me that there is nothing wrong with using finishes near a furnace because of the low concentration, etc., just as you are hearing now. However, I always had a 2nd thought about it because I only had one chance to prove everybody wrong, and XXXX Happens.
Personally, I would be concerned, and I would move to a different workspace, quit using finishes with flammable solvents and thinners, or provide adequate ventilation. And, the ventilation is something I should be doing wherever I am using the finish..
