Tiny rings and finials
See more from Hippie3180
Hippie3180
Texas
We've done a few finials before, mostly in prototype pens, but this was our first time with rings. They're kind of small, I think I'd like them a bit thicker, but you work with what you have. I've since ordered some thicker ones.
Alumilite blanks cast in house.
d_bondi
Utah
I really like the look Michele.
Are you purchasing the rings (and if so where) or are you drilling a hole in sheet brass and cutting them out?
Also, I'm curious, is there a tenon (threaded or not) holding the finial and ring on, or it is just glued?
Hippie3180
Texas
The finial does have a tenon + threads and the body has threads. Just like how the section fits the body.
Many folks who do rings make them from sheet metal. I don't have the means to do that, so I buy discs and drill them out (which is a bit tricky.) If you look around online you can find the finish/size you want. I just ordered some brass, aluminum and copper to try that are a bit more thick than the rings pictured.
Hippie3180
Texas
Great looking pen. Like the use of the metal rings.
Question to members: Would local hardware stores have washers of various materials?
I'm sure they do, I'm not sure if the hole might be too big/or not? And I'm not sure about what finishes are available.
Discs are cut with a disc cutter and come in a variety of finishes, it's just kind of a deal to source them and to find the thickness you need.
