Another set of Cornhole boards.
See more from Curly
Curly
Saskatoon SK., Canada.
bishop40 showed a nice set of corn hole boards this morning that reminded me of ours I made this past summer. https://www.penturners.org/threads/cornhole-anyone.179505/ Got the orders from Marla to make a set after playing the game at her cousin's place in 2022 for our RV trailer we got last spring.
I used 1/8" Cherry plywood and Oak strips to make a torsion box. I was hoping it would be lighter than the usual plywood and 2x4s. I don't know if they are and would have been if I had used Spruce or Cedar rather than the Oak but when you have a small pile of scraps you go with what you have. I laid out the Oak and glued with Titebond III a few pieces at a time, held in place with weights. I made the hole reinforcement pieces on the lathe, screwing them to a faceplate for turning. Gotta get a little lathe work into the project. 😉 When done I glued the second sheet on top. The boards are edged with Black Walnut. I cut out the hole with a hole-saw so I could use a bearing guided router bit to clean up. Edges were all routed with a 1/8" round-over bit. The legs are oak and I need to add some removable pegs so they don't shift while playing the game. I sanded and then applied Tried & True Oil for a finish. I might have sanded a little too fine as the corn bags often shoot right up the board and off the end. The torsion box construction might be a little louder than a solid plywood surface. When the bag hits it makes a good thunk. I have to play with someone that has "normal" ones to be sure. If ever called upon to make another set I will use foam board as a core because it will be easier and faster, possibly lighter too.
bsshog40
Omaha, Tx
They look good Pete. The only reason I went full thickness on mine is we play alot and I'm hoping they last for years as I don't feel like making anymore. Lol also, here's the method I found for checking slickness on your boards. Of course, they will probably start slowing a little after a lot of play.
We love the game. I even made a score stand about 4 years ago. Put a 2 beer holder on the back. Lol
Curly
Thanks for the link. A scoring stand or easel is on next years list especially since the score is forgotten during the course of the game and refreshments advance. I want to keep the size and weight down as the trailer isn't big and there isn't a lot of room for the "things" we need to bring camping.
carlmorrell
Cary, NC
Last summer, my daughter, her boyfriend, his brother and gf wanted cornhole boards. It turned out to be a good learning experience for them. We hooked up the trailer and headed for Lowes. I got out the miter saw and a few other tools. I pushed the circular saw, and jigsaw, but let them all use the miter. It was probably the first time any of them had run a saw.
Curly
Curly , I think it would be better for you to practice throwing snowballs through the hole , rather than half eaten cobs of corn .
Well actually I could try now because we did get our first snow ❄️☃️❄️ of the year last night. I like the taste of corn better though so I'll stick with that.🌽🍿
Muddydogs
Utah
These and the ladder toss game are on my list to make. Yours are very nice.
Curly, do you frequent a reloading forum? Maybe it's casting?
Curly
No I don't reload so am not on any of those kind of forums. In my 20's I shot a black powder musket and cast the 58cal mini balls for it but that's as close to casting as I have gotten. Just woodworking related forums.
