App Database Update - 7-22-23
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
A new database update is available for download from the IAP server. The apps should download it automatically within 24 hours; however, you can manually initiate a sync. On Android, you can go to options->sync and choose Sync Now. On iPhone/iPad simply close & reopen the app & it will initiate a download (do not delete the app - just close it & restart it).
Main update is the addition of Mr Woodturner in South Africa to the suppliers with over 300 kits, including a number not carried by other suppliers in the database.
Also added some new kits, including the new Magic Wand kit by Woodturningz as well as a number of edits for better consistency of kit names & descriptions, and various bushing & tube dimension updates.
Please let us know if you see any errors or if you can provide any missing dimensional info.
ramaroodle
Seattle
I still can't seem to update. It says version 1.17 from 10/15/22. What should I do?
Rob H
Naches, WA.
Does the Android version not work correctly on Chromebooks? I installed it a month ago and just looked and it said last update never so I tried initiating a manual sync, which it said it started but waited 20 minutes (1 gig internet) no charge. I just tried clicking on the first kit and it crashes.
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
Make sure you are using the latest version on Google Play. A new version was posted a few days ago.
A complete database download will probably take 30 minutes or more. Photo thumbnails should start showing up as the database download progresses.
Rob H
Naches, WA.
says version 3.0 in the app just watched it download 96 MB then the number stopped and didn't increase so I assumed it was done but said never and crashed when I clicked the first item in the list. I did find by default it didn't have permission to access storage but I fixed that before trying a manual update
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
The complete database is about 2Gb. I don't have a Chromebook, so I can't say there isn't a compatibility issue, but it should work on any Android device AFIK.
I haven't had a chance to try the new version yet - I'll try to do that later today.
Have you tried any of the other kits?
Rob H
Naches, WA.
Found the issue. If I leave it in phone mode (sized for phone) it works fine, however if I change to either tablet or resize-able mode it crashes once I click on a kit. Kinda a bummer because I don't see as well as I used to so making it larger is kinda the point of using my Chromebook.
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
That's interesting. The only Android device I have is a K88 tablet & the app works just fine on it. I will ask our Android developer to investigate the issue.
What is the exact model of your Chromebook?
Rob H
Naches, WA.
Asus Vibe CX55 Flip 15.6
rd_ab_penman
Red Deer, Alberta, Canada.
Hi Edgar,
I noticed that the tube length for the Coyote Twist BP is incorrect.
It should be 2.27" and not 2.98"
I also noticed that screen color is now a Brown color which is not as easy to read as
the old version with the white screen?
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
Thanks, Les - I'll make that correction.
You can change the color settings for the detail page through the Settings app. Click on the gear icon at the top of the main screen & it will take you directly to the settings.
