Triming label cast pen blanks.
JohnU
Ottawa, Illinois
For trimming the label prior to casting I use a razor blade. You'll want them oversized to make sure you cover the entire brass tube. Cutting them to an exact size will be a problem if you don't get them perfectly straight. For blanks already cast I use a pen mill or sanding jig.
ol salt
nicholasville, Ky
Are you asking about cutting the label before it is applied to the blank or the trimming after it is applied to the blank?
Also are you printing your own labels / graphics?
calabrese55
Triming both ends of the blank before turning on my lathe and getting them square
calabrese55
Finger Lakes Region New York
there are several ways to accomplish that. I mostly use a sanding disc with a 90 degree jig and quit when I get to the brass tube.
Here are several youtube vids
general link https://www.youtube.com/results?search_query=trim+pen+blanks
specific vids on the subject
Then there are the tool you can buy
calabrese55
