Turning with a Bedan tool?
Woodchipper
Cleveland, TN
I was watching a video where the guy was demonstrating using several turning tools to turn an aluminite blank. I was wondering if anyone has used a Bedan tool for turning blanks. If so, is it best on certain materials as wood, acrylic, etc.? I made a Bedan tool a while back and used it on a couple of turnings. TIA.
monophoto
Saratoga Springs, NY
I have a bedan. I find that its great for removing a lot of waste quickly, and also for making tenons. I've never mastered the art of turning beads with it.
I almost never turn plastic, so my experience is limited to wood.
Fayetteville, North Carolina
Well, a bedan is basically a flat scraping toold so you could use it to hog off sections evenly and probably fairly quickly. Don't how well it would work for shaping but I imagine it would be good for smoothing out the final shape if it is uniform in shape.
monophoto
I find that it performs much like a skew chisel, only one that is much thicker. Can produce very clean planing cuts. But like a traditional skew, things can go really wrong really fast.
Pierre---
France
Bedan is very much in use in France, for making tenons (using it as a parting tool) and for shaping (using it as a skew): both tools in one. I use it a lot for both wood and resin.
Escoulen's advice : "One egg every morning is the best exercise." Turning it, not eating it...
howsitwork
Thirsk
I use one sometimes as the extra mass helps prevent vibration. However I use my 1/2" round skew much more .
with the bedan tool I ground the edges ( corners) off the shaft of the tool slightly which improved its ease of use for me.
bradh
Aurora, Ontario, Canada.
I purchased one of these years ago, got a bad catch the first time I tried it and have been hesitant to try it again. I have seen some debate about which side should be up when using this tool, seems to be 2 schools of thought. Thanks for the video, I plan to watch it and take another shot at using this tool.
Woodchipper
Cleveland, TN
bradh, you are most welcome. Getting back to turning and penmaking. Need some way to spend $$$$. Wife asks when I'm getting a cheap hobby. Anyone know of one?
monophoto
There are naturally two schools of thought - the tool has two totally different sides.
Seriously, I normally use mine with the bevel down, but sometimes I use it bevel up. I don't think it matters much when making tenons, but for making a bead, the bevel up orientation seems more natural to me.
