Advice please. With caps or without?
Alan Morrison
N Ireland
Using caps means loosing a lot of ribbon.
Not sure what you are asking. Now this is just an eye thing and opinion. I think if the center line was carried around the same pattern it would look better. But I do get what you were after with the breaking up of the center line. It works.
ed4copies
Local Chapter Manager
Racine, WI, USA.
If this is a single-barrel pen, I would use much shorter caps--maybe 1/8" (prox 5 mm).
This would "finish off" the look as it transitions to hardware and yet show as much of the
pattern as feasible.
FWIW,
Ed
TDahl
Brentwood
I actually like both. The long ribbons with the darker background works really well for that combination. That caps work well with the lighter combo. I do agree with Ed that shorter caps might be better. If I had to pick one option, I would go with no caps.
You might also consider continuing the no cap design to the body of the pen (as long as everything lines up.) That would be a real striking design. Well done. Thank you for sharing.
leehljp
Member Liaison
Tunica, Mississippi,
Without Caps as a blank looks better to me too, however, I do know that looks often change when mounted in a pen, and with the right color pen choice ( Gold Chrome, Silver, Brass, Copper,) the light colored capped one might outshine the uncapped one.
Lew
Fair Oaks Ranch, Texas
They are both beautiful, great pieces. But I like without caps better. As Lee says, though, it depends on what the finished product looks like. It would be interesting to see how they both wind up.
Kenny Durrant
Sachse Tx. 75048
Wow! Did you get you question answered? Just in case you didn't I'll add my 2 cents. I like both blanks but I'd prefer the caps. Also I like the ribbon on the right better than the left. I can see cutting away the nicer ribbon for caps would be a tough call but like Ed I think it would flow better with the kit. So if I was to reconstruct the two I'd use the ribbon on the right with very thin end caps. IMHO
howsitwork
Thirsk
Sorry I know I am in the minority but i like the lighter one for a single barrel pen.
Narrower caps would work with the right hand darker colours but they finish the flow off to my eyes otherwise the ribbon goes no where.
Have to say all my time on this site and never heard the phrase caps used for trim rings.:) Excuse my confusion. Yes either way works well but if doing a 2 piece pen Then definetly caps as you call them work better because it breaks up that line and trying to line up designs from cap to body of a pen is tough to do. If a single barrel pen then either way works but agree with others, thinner "Caps" look better.
sorcerertd
North Carolina, USA
For starters, that's a very nice design! What about a small frame instead of a full cap like that? Something like the divider between the design and the cap without the cap. Or like Ed said, a much smaller cap. That or...
You obviously like challenges so how about this, make the ribbon curl at the ends and wrap around to tuck under the existing end of the ribbon? I tried to photoshop (gimp), what I picture in my mind but it's a pretty crude representation. Hopefully this gives a rough enough idea of what I meant. I don't know for sure how you would curl/fold it into those bands, but there is the challenge, right?
Alan Morrison
N Ireland
FWIW,
Ed
Thanks for the comments, Ed. I think that my next attempt will be on a longer tube, eg. a Knurl, which will allow me the longer ribbon with the 2 'folds' in it as well as the end rings.
These were a couple of 'suck it and see' prototypes. I had tried shortening the long parts of the ribbon between the folds but it didnt look right.
Alan
Alan Morrison
N Ireland
Thanks Hank. I prefer the blank without the ends as well though my reservation re. the other one is that the ribbon has only one 'fold' in it. I tried shortening the length of the ribbon between the folds but it doesnt look right. A longer tube should sort that out.
Alan
Alan Morrison
N Ireland
Thanks for the comments, Lew. I prefer also the colours of the one without the end caps.
Alan Morrison
N Ireland
Thanks for your input, Kenny. As I said to Ed above I think that a longer tube will solve the issue.
Alan Morrison
N Ireland
Sorry for the confusion, John. I should have called them trim rings. ( what do I know???)
These were for single barrel pens. I will post a photograph later.
Alan
Alan Morrison
N Ireland
Challenge accepted, Todd.
Thanks for the comments.
Alan
