Need Help with Composit Blank (Wood.Acrylic.Wood Sandwich)
KarlSangree
Secane, PA
Let me preface this by saying that I am a machinist with some experience turning wood pens, but absolutely no experience with acrylics.
I am trying to make a "thin blue line" pen for an animal cruelty investigator buddy of mine. Here's what I've tried so far:
  1. Two pieces of mahogany on either side of a pen blank mold, then poured blue dyed MAX CLR resin to fill gap in the middle. Cured overnight at 60 psi in pressure pot.
  2. CA glue (Starbond medium) a 0.125" x 0.750" x 3" piece of blue acrylic between two 0.3125 x 0.750" x 3" pieces of mahogany. Clamped tight and let sit for 2 hours.
Both of the blanks looked awesome before turning. However, during turning, both blanks exploded towards the end when the blanks got a little thinner. I am guessing it's either my poor turning technique or I'm using the wrong tool. The 100% wood pens I've turned have all been exceptional, but these sandwich blanks have me a little frustrated. I am using the chisels that came with the lathe. They are a set of Penn State Industries Benjamine's Best Carbide. I'm using the one equipped with a (3/8"?) round carbide cutter. I'm turning at around 2,000 RPMs.
Any help for this acrylic newbie would be greatly appreciated.
farmer
NV
Used slow drying epoxy .. score the acrylic
turn using a live cutter
Laminate and then drill and dowel the pieces if you have to .
Thin blue line !
Do one slit and then use blue veneer .
egnald
Columbus, Nebraska, USA
There are SpectraPly Thin Blue Line blanks out there, but I don't know who makes them. I have had the best luck with the Alumilite Thin Blue Line blanks from Turner's Warehouse. Alumilite turns just great! - Dave
Painfullyslow
Connecticut
If you are going to make your own, I second @farmer 's approach. Scuff up both sides (wood and acrylic), wipe down with acetone as some woods are oily and it can affect the bond, use 2 part epoxy and clamp but don't crank it super tight or you will squeeze out all of the epoxy.
Personally I use T88 epoxy from System Three. It takes a full 24 hours to cure but so far I haven't had any failures on pieces where I have used it.
KarlSangree
Secane, PA
Thanks all. I'll try your suggestions and let you know in a few days... as soon as the new T88 epoxy gets here. I think my biggest problem is the carbide button style chisel. I tried using a skew chisel and it was working great, albeit a little rough looking from my lack of experience. I went to clean up the marks from the skew with the carbide button and boom went the dynamite.
I'll try let and you know in a few days. The epoxy will be here tomorrow, and the T88 website says 72 hours full cure time.
KarlSangree
Secane, PA
I tried the suggestions posted previously. I scored the acrylic, not too much clamping pressure and so on. Turned the blank entirely with a skew chisel instead of the carbide button. Not entirely happy with the colors but at least I was able to finish one. Still waiting for the T88.
Thanks everyone for the help!
KMCloonan
Round Lake, Illinois
Not sure if this would help or hurt the situation, but 2000 rpm seems pretty slow. I think most of us turn close to as fast as our lathe will let us. I routinely turn at 3500rpm. Going faster and taking light cuts may reduce a "catch" which results in a blow out.
My 2 cents anyway.
PS - the finished pen turned out awesome.
KarlSangree
Secane, PA
My 2 cents anyway.
Wow! And here I was thinking 2000 RPM was too fast. Newbie mistake... too much time on the metal lathe spinning material at 400 RPM lol.
I am going to try again when I get the recommended (T88) epoxy and I'll try the higher RPMs at that time.
