.308 Assortment
See more from Sataro
Sataro
Mexia, TX
No turning on these except for polishing the brass. The two on the right are fixing to be delivered shortly. They are being traded for a used Wen dust collector.
Sataro
Mexia, TX
The two pens on the right was traded off & delivered yesterday. Here is my dust collector that I traded for. It is a small dust collector that will be setting up behind my lathe.
RunnerVince
Ogden, UT
@Sataro I think I could figure it out, but any chance of a short write-up on your process for these? I think people here in Utah would go nuts for these.
Sataro
Mexia, TX
Ray-CA has posted a very good link with visuals of the steps to make the bullet pens. One step that I do different is the drill bit size. I think the 7mm drill bit size is slightly too tight since the brass casing allows no room for expansion when inserting the transmission. So I use a 9/32 drill bit. I do not solder my tubes in but use CA thick instead. I think soldering would be better. I may have to try that myself.
Ray-CA
San Diego CA, USA (SAN)
I just finished up another one. The 7mm hole was really tight and I had to re-drill to 9/32. Thanks Sataro for that tip!
Alan Morrison
N Ireland
Ray-CA
Here is the conversion 9/32 inch to mm. I am going to start using the 9/32-inch bit now.
9/32 inch to mm - Converter Maniacs
Here is the answer with the math that shows you how to convert 9/32 inch to mm: 9 / 32 = 0.28125 0.28125 x 25.4 = 7.14375 9/32 inch = 7.14375 mm inch to mm Converter Here you can convert another fractional inch to mm. 9/33 inch to mm Here is the next fractional inch on our list that we have converted to mm.
