I’ve been working on fountain pens
See more from Alchemist
Alchemist
Central Valley, California
This is a personal favorite of mine…
Alumilite Clear Slow custom blank for the cap and body.
Black ebonite for the section.
Bock #6 nib
The process:
Drill the section with a 7mm, cut the tenon down to 10mm and chase with a 10x1 threading.
Flip around on a delrin mandrel I made. Shape it. Then drill and chase with the appropriate sizes and tap it for a Bock housing.
Body was squared off, a tenon cut for a 14mm x 1 thread chase, drilled with a "U" drill to the appropriate depth for a converter and tapped for the section. Flipped on a mandrel and shaped.
Cap was drilled and tapped with a 14 x 1 tap and flipped on the mandrel to shape.
Pen was roughed with carbide tools and final shaping with files. I like files for handling chatter and shaping smooth… sanded from 320 to micromesh. Buffed using Tripoli and dimaondcast. Given a warm bath of Dawn and ultrasonic.
C & C is welcomed
Thanks!
Dave
Alan Morrison
N Ireland
Excellent job, Dave.
I like that you have just a minimal step from cap to body.
Don't understand the 'Dawn and ultrasonic'. I assume that Dawn is washing up liquid, but what is the 'ultrasonic' bit mean?
Alan
Alchemist
Alan
Dawn liquid soap and an ultrasonic cleaning machine. The vibration helps get the crud out of the threads and any other gunk that may have stuck to the surface of the pen. I have a jewelers ultrasonic from harbor freight for cleaning small things. It uses tiny vibration to knock crud off.
Ironwood
Mackay. Australia
That's a great looking pen Dave.
Single start threads are fine, only real downside, as you say, plenty of turns to uncap. Though you can still cut that down to 2 turns, which feels a lot better than 4. I use double start threads, and aim for 1.5 or 2 turns.
My first kitless pen has about 4 turns, I use this pen most days when I am at home, it bothers me a little, but not so much that I have gone to the trouble to modify it.
Alchemist
Triple start leads are far too pricey for me, although, I'm not opposed to get them in the future. I will get the turns down. I have a pen I use at work that has 7 turns. It's utterly annoying, but when people see it, the cap is already off 🤣
PatrickR
Rural America
Nice pen! I like the section shape.
triple lead threads only effect how easy it is to engage the threads. 3 spots vs 1. Once engaged the pitch and where it comes to a stop will determine total turns. The easiest way for me to effect turns is simply drill away cap threads (bit same as the thread size) until its where I want, keeping pattern alignment in mind. I'm happy with anything that's between 3/4 and one. Much less and there wont be many threads engaging.
Alchemist
Yes, thanks Patrick! This is what I plan on doing in the future. My larger chuck and bits should be arriving soon. Thanks for the tip!
MedWoodWorx
Greece
Bock #6 nib
The process:
C & C is welcomed
Thanks!
Dave
Very nice work, bravo. Even the stand you used is awesome.
MedWoodWorx
Greece
Bock #6 nib
is there a reason why most penturners use ebonite for the section/nib part?i wanted to ask whether ebonite or epoxy materials can take threads better, cheers
floatslow
Long Beach
Bock #6 nib
The process:
C & C is welcomed
Thanks!
Dave
I appreciate that you describe your process with thoughts on how and why you are sequencing your steps. Kudos and nice pen
