Drilling clear acrylic
Penultimate
Bartlett, IL 60103
I'm trying to make a pen body from clear extruded acrylic and it cracked while drilling. I had 0.5 inch diameter rod in my collet chuck drilled progressively larger holes with lube to .360 ID. I got a bunch of stress cracks.
Any advice on drilling? Do I need a different material?
Thanks.
Mortalis
Bardstown, Ky
I saw this post
while reading yours.
jalbert
Louisville, KY
I would use cast acrylic. Extruded has a higher propensity for cracking. Also make sure you are using lubricant and appropriate drilling speeds. Clear Acrylic will develop crazing, which appears as cracks, if the above 2 variables aren't addressed.
duncsuss
Wilmington, MA
It is unwise to lubricate with alcohol or an alcohol-based) product, this is known to trigger cracking in Plexiglass and other acrylic acetates. Google "pmma alcohol crack" if you'd like corroboration of this.
Why does this happen? LINK to an organic chemistry forum that discusses it.
I use tap water with a drop of dish detergent to cool and lubricate when I'm drilling resin blanks; I protect the lathe ways using magnetic floor vent covers (the ones designed to cover up AC floor vents in winter - LINK to Home Depot)
duncsuss
Wilmington, MA
Duncan...what do you think about using PAM as a drilling lubricant?
Tony - I've tried it and found it's a great lubricant, but I don't think it cools either the bit or the workpiece as effectively as water. (Plus it's a bit messy to clean up afterwards!)
edit to add: I've also used Tap Magic and "pink" automatic transmission fluid, both of which are great lubricants but don't do much to cool things off, so I tend to keep them for when I'm cutting threads.
PatrickR
Rural America
I have seen polished plexiglass craze simply by being exposed to VOC fumes.
Penultimate
Bartlett, IL 60103
Hi
Thanks for the great suggestions. I used PAM as a lube but I didn't let the bit cool enough. I'm going to get cast acrylic and use water.
TonyL
Georgia
Thank you. I may try my Bostik Blade and Drill bit lubricant the next time I drill clear.
Woodchipper
Cleveland, TN
Tried to drill an acrylic blank. Got in a hurry and the blank glued itself to the bit! Now I consider the time it took to remove the blank from the bit!
PatrickR
Rural America
For truly effective cooling, flushing with fluid or air would be required. Oils applied to the bit or in the hole will help with cutting but very quickly reach the same temp as what is being cut. I plan on adding a nozzle to blow air into the hole on my set up to keep both hands free.
