Gillette Sensor razor
See more from Monty
Monty
Group Buy Coordinator
Pearland, Texas, USA.
Does anyone know if the Gillette sensor blade will fit on the Mach 3 or Fusion head or if a Sensor head is available for any razor kit available?
Monty
Thanks for your reply. I haven't seen any either but thought I'd ask if any one else knew of one. I had a customer ask if I could make a razor that would accept the Sensor blades.
wmillman
Prince Edward Island, Canada
That one uses the Mach 3 blades like most of the others
I re-read your question and I now understand what your looking for, I did a set from William Wood-Write a couple of weeks ago and the instructions for that kit says "This razor kit is designed to be used with Fusion cartridges." then I lookup what Lee Valley has and it says "Uses widely available Gillette Mach3 refills." which look similar but different. Now looks like the Gillette Sensor blades are different again, too many different blade types under the one brand name if you ask me.
