This makes things easier
Alan Morrison
N Ireland
I borrowed this metal punch from a jeweller friend and it makes short work of cutting out rings.
leehljp
Member Liaison
Tunica, Mississippi,
I made mine the hard way: placing between two sheets of plywood and drilling the holes. That looks MUCH better. I checked Amazon and they run $130 US with not quite enough sizes.
leehljp
Member Liaison
Are the rings used to make clips?
What Alan said:
The rings for separating segments give it a different perspective, AND keeps two different wood/colored segments from bleeding onto one another, which doesn't happen often but does with certain types and colors.
Alan Morrison
N Ireland
Arigato gozaimasu, Hank.
Your picture was a lot better explanation than my words.
Alan
darrin1200
Lyn, Ontario, Canada
This look like a great clip aid as well. What metals, and thickness, would this work with?
Currently, I'm hand cutting and filing to shape.
I'm working with:
Nickel silver
Bronze
Aluminum
Titanium
Stainless
Alan Morrison
N Ireland
I'm working with:
Nickel silver
Bronze
Aluminum
Titanium
Stainless
Darren, I just punched the brass and aluminium sheets that I have currently. They are 0.04mm I believe and punch very easily. What thickness have you got and if I can I will try some?
Before borrowing this I drilled between plywood sheets and reduced the outside with tin snips. This punch is an absolute breeze to use and cuts both the internal and external diameters, which is very handy.
Alan
