“Short” Blank Size
MRDucks2
Bristow, IN
As I am working with a bunch of wood from a retired turner, I have some pieces I can separate usable "short" blanks from pieces for casting or inlay.
My question is, what is the preferred size range for a "short" blank. My standard is 5-1/4" with a range of 5"-6" for regular blanks.
I have seen mentioned that a blank need to be 2-1/2" for a Sierra. Is that a good bottom for squaring and turning or would 2-5/8 be better?
Thanks for the feedback.
magpens
Canada
If you are talking Sierra Twist, then 2 1/2" is perfectly adequate as finished barrel length is 2.21".
Even for a Sierra Click, which has finished barrel length of 2.42", a starting length of 2 1/2" is OK if you are careful.
magpens
Canada
Even for a Sierra Click, which has finished barrel length of 2.42", a starting length of 2 1/2" is OK if you are careful and reasonably skilled.
greenacres2
Northwest IN
For most single barrels, 2.5" to 2.625" gets it there. But, there's a large number of kits that push the 3" mark--Vertex Click, Atlas (Patriot, Polaris), many of the PSI "themed" kits (Celtic, etc)--all at 2.88" to 2.90".
earl
Woodchipper
Cleveland, TN
Yep, segmented blanks. I just cut a piece of a "board" from the $5 bin at Woodcraft. I got at least 12 blanks, 3/4x3/4x5, out of it and still have some left over. I pulled the copies of my pen instructions and that went up to 24 blanks for many kits. The five inch blanks are for Slimline kits, the other kits take blanks of not more that about 3 inches.
greenacres2
Northwest IN
Yeah, when i cut a board, i sometimes cut length i need for what i'm working on, leave the rest intact so there is a degree of flexibility. Band saw is always plugged in!!
earl
