Let Roi Royale in Black Ash
See more from Dehn0045
Dehn0045
US
My penturning has slowed to a crawl. Was able to finish up this one this weekend. Hoping to get back to finishing at least one a week while the weather is cooler.
Dehn0045
US
Well done! What drill size did you you use, please?
Thanks Tony, it's been a couple weeks since I drilled and glued this one, but I'm reasonably certain I used a size U bit. Edgar's response in this thread has the instructions, the assembly is a tad unusual. http://www.penturners.org/forum/f14/ugh-need-help-my-leroi-royale-154379/
Another thing that I found is that the ring on the clip is slightly smaller than the finial diameter. I turned my blank sized to the finial, so it kinda looks like a poor fit. I'm not sure if there is a better option or if it is just the way the kit is designed. Maybe split the difference between the clip and the finial...
