I'm thinking it will be more economical to buy a set of drill bits rather than continuing to buy a single bit here and there.
If I already own a Drill Doctor for sharpening bits, what is the benefit to buying a more expensive set compared to a cheaper set?
Do you think there is much of a difference between the sets sold by Grizzly, HF, and a random seller on Amazon? And which would you recommend? (Probably can't afford high end right now.)
I'm leaning towards these: (thanks for the recommendation randyrls)
115 piece drill bit set.
TiN Coated 115 pc. Drill Bit Set | Grizzly Industrial
Metric set.
Metric Drill Bit Set, TiN Coated, 25 pc. | Grizzly Industrial
Metric set.
