Green syringe filler
See more from jalbert
jalbert
Louisville, KY
Here is a fountain pen I finished up from emerald water acrylic. It's a bit less transparent than some of the other colors in the water series of blanks, but still transparent enough to see the ink in the pen when it's filled. It's got a handmade nickel silver clip, and #6 jowo nib.
As far as the filling system goes, it uses a built in syringe so to speak, where you submerge the nib in ink, pull up on the knob of the syringe shaft to draw the ink up, and then screw on the blind cap on the back of the pen. Then you're ready to write. It's essentially a "poor man's piston filler."
Marcros
United Kingdom
that is a very nice pen indeed.
I am new to kitless pens, and have only made a couple of cartridge/converter fountain pens. Do you modify the feed when using a different filling system? My next step will be an eyedropper filler if that is relevant to my question.
jalbert
Louisville, KY
I've never had to modify a feed before when using a non-C/C filling system. I believe filling systems that require breather tubes may require some modification, but there's definitely nothing extra required with an eyedropper.
magpens
Canada
VERY lovely pen, John !!!!
Did you make the components for the syringe ?
Does anyone besides BTW sell the water series of blanks ?
jalbert
Louisville, KY
Thanks Mal. I made all components except the nib unit. As far as I know, Beartooth is the only ones that sells the water blanks. Exotic has/had some called "lucitylic" blanks in various colors at one point that were essentially the same thing I believe.
