Deco (Jr Harold Twist) in Black Canvas Micarta
See more from More4dan
More4dan
Katy, TX
I saw this new kit in the Bash and immediately ordered it. Even nicer than I expected. My first thought was to use Damascus steel but the piece I had was a bit too short. I remembered I had a large block of Micarta in my knife making supplies and decided to give it a go. The Micarta is made of layers of Black canvas fused together under pressure and temperature with a phenolic resin. The canvas gives a very unique pattern. It turns, sands, and polishes like a nice hardwood. It is really tough stuff and impervious to most chemicals. I dry sanded to 500 grit and polished with pink rouge on the buffer.
[ATTACH=full]248196[/ATTACH][ATTACH=full]248197[/ATTACH]
Danny
Sent from my iPhone using [url=http://r.tapatalk.com/byo?rid=93064]Penturners.org mobile app[/url]
magpens
Canada
That pen is very beautiful !!!!
I would like to get some of the kits.
Can you please specify the tube length ... I understand it is a 27/64" tube ... and also the finished diameter of the barrel .... Thanks.
More4dan
Katy, TX
Instructions and dimensions for the Deco kit. Purchased from Exotic Blanks.
  • deco_pen_kit.pdf
magpens
Canada
Thanks, Dan.
But that does not include the tube length ... which I would greatly appreciate knowing if you could provide, please.
OZturner
Sydney. NSW. Australia
Great Pen, Danny.
Excellent Blank Material, Fit and Finish.
Love the Barbed Wire, as shown with the Knife, would also make a great Blank, if thick enough.
Thank you for showing,
Brian
magpens
Canada
Thanks very much for measuring, Dan. . That gives me the info I need :)
I was hoping it was right around the 3" length.
I measure the body at 3.0". The tube might be slightly longer as I sanded the ends square and may have nicked the tube.
magpens
Canada
Welcome to IAP, Clare !!!!
If you post an introduction in the Introductions forum your name will be entered for a possible prize ... special for newbies !!!!
More4dan
Katy, TX
Gorgeous looking pen . Love the way that material turned out. Really eye catching.
May I ask what method you used to do the finish on your pen ?
No finish applied. Just sanded and buffed.
Thanks everyone for the kind comments. I've used Micarta for many knife handles and really like how it turns. I use to make my own, I might have to try making some pen blanks.
Danny
More4dan
Katy, TX
I assume the resin is what is polishing??? Does it come up to a high shine???
Looks good from here.
It will take a similar shine to acrylic when sanding and polishing with the same technique. You can also stop sanding at a lower grit to add some grip with a light buff to still add shine. Paper Micarta shows almost no grain, it makes a nice substitute for ivory or water buffalo. Their is also one made from linen with a very fine grain. The resin is a pressure/temperature set phenolic. It is extremely durable. Colors are very limited. It's made for electrical insulating boards.
