Stained maple pen with case
See more from Kloss
Kloss
Rochester NY
I know, simple maple is boring; especially for a pen, but I am lucky enough to have a lot of maple wood and oak available from my backyard.
But you know what....not figured/simple wood can be a wonderful canvas.
bpgoldo
Carlsbad
Kloss, with your stain gradient and skill at the lathe and finish, you have make simple...special. And that's sumpin' to be proud of....and do a lot more of.
Kloss
Rochester NY
Thank you guys.
I have been playing with stain and dyes for a couple of months and I am still learning.
For the gradient, after properly sanding, I just started with a black stain in the airbrush. I brought it down using some 0000 steel wool.
Did the same with the red stain that, having a white background, went towards pink.
For the cases I use maple branches with a diameter larger than 1 inch; sometimes oak.
Usually I roughly turn one part of the case, bore it with a forstner bit (I think the 3/4 of inch diameter) around 7/8 cm deep (depends on the pen style). Mount the other part on the lathe, do the same (using a smaller forstner bit, I think the half inch) and make half inch tenon to have a tight fit so I can turn the case.
I finish them separately just using scrap wood pieces mounted on the scroll chuck with 2 inches tenons.
I sand the inside with a little drum mounted on the drill press, then apply some lacquer to avoid any dust to stick on the pen. After the lacquer is cured, I glue some foam inside at the bottom of the two ends of the pen case. This will avoid the pen to travel around the case.
Please excuse my English.
liljohn1368
Brooksville, MS
Thank you guys.
This is nice to know. I could mount this on my goose call insert mandrel. Thanks for sharing. Really nice pen by the way.
mark james
IAP Collection, Curator
Medina, Ohio
Both the pen and the case are wonderful!
Thank you for sharing, the case gives may design opportunities.
And what you did with "plain wood" is wonderful. I love local woods, and feel they have their own subtle beauty.
Great set!
