Bock 5mm nib unit dimensions in inches with Drill sizes
More4dan
Katy, TX
Attached is my dimensions for the Bock 5mm nib and feeder triple unit. Also my the drills I use to create the front section. Let me know if you have questions or comments. The Tap for the threads is a metric 0.6 pitch while the diameter is slightly over 0.25"
Penultimate
Bartlett, IL 60103
Greetings
Thanks for the sketch. I have a .dwg and a .dxf of the nib section if anyone is interested. PM me and I will send it. I couldn't upload the drawings to thi thread.
PAturner
PA
In steps one through 4, (prior to reversal) is the blank mounted so that the outside-threaded end is towards the tailstock or the headstock?
Penultimate
Bartlett, IL 60103
Greetings
I think I uploaded the files properly. There are two .dwgs and one .dxf
Good luck. I did these to the best of my abilities and they work for me in my designs. I hope they are helpful.
  • nibs.zip
More4dan
Katy, TX
Threaded outside end toward the headstock for steps 1-4. I use a chuck or you could use a collet.
