Relay for Life
See more from campzeke
campzeke
Tampa, FL
Last week my wife and I were in a Goodwill store and I found a Relay for Life lapel pin in a box of assorted pins and tie tacks. I immediately started thinking of ways to use it on a pen. Well .... here is what I came up with. I plan to donate this one as a Relay for Life fund raising item.
campzeke
Tampa, FL
That's pretty cool! How did you attach the pin to the clip?
I figured out where the ribbon contacted the clip and very carefully roughed up the clip with a small file. Then wiped everything down with lacquer thinner to remove any dirt or oil then attached with a couple of small dabs of JB Weld.
