Polarization and Glare
Sylvanite
The topic of glare, and how light polarization affects it seems to crop up over and over - along with some common misconceptions. I'd like to address a few of them here.
First off, just what is "glare"? Glare is a strong direct reflection that distracts from, obscures or washes out details in your subject. Some direct reflection is not necessarily a bad thing. It provides a visual cue to surface shape (what is known as a specular highlight). Without a little glare, it's difficult to see the quality of a gloss finish. Just how much is too much varies with the viewer. Each of us has our own preference. I've had photos where one person commented that he wanted to see more shine - but another complained about the glare. So, don't worry about the naysayers.
Ok, I've used a term without defining it first, so let's back up and talk about different ways that an object can reflect light:
  1. Direct Reflection occurs when light hitting it bounces off solely at the complementary angle (angle of incidence = angle of reflection). This is typical of smooth surfaces.
  2. Diffuse Reflection occurs when light is scattered. When light hits a matte surface, it is reflected in a variety of angles.
This distinction becomes important in photography, because the two types of reflection behave differently. I'll explain more as we go.
Now, what is polarized light? This is not easy to imagine, because the common analogies don't always work. Nevertheless, if you think of light as waves, then the wave frequency determines color, the amplitude determines brightness, and the angle of the wave is its polarization. "Polarized Light" consists of waves all aligned at the same angle. Unpolarized light has equal amounts of waves at all different angles. Partially polarized light is a mix of the two.
When unpolarized light meets a polarizing filter (or polarizing reflector), then the waves that align with the filter pass through. The waves that are perpendicular get absorbed. The waves that are at an angle to the filter are partially absorbed and partially transmitted - with the transmitted portion all aligned. The result is that 50% of the light is blocked, and the remaining 50% is polarized.
When polarized light meets a polarizing filter, the effect depends on the relative angles of polarization. If they are the same, then the light passes through unchanged (and undimmed). If they are perpendicular, then the light is completely absorbed. At other angles, the light is partially transmitted and repolarized in the direction of the filter.
This can be confusing, but it is necessary to understand when using polarizing filters in photography.
Almost all light sources produce unpolarized light. That includes candles, the sun, and artificial lights (incandescent, fluorescent, and LED).
Although it's theoretically possible to make a polarizing diffuser, most diffusers do not polarize light. Diffusers made for photography - including light tents - do not. In fact, diffusers generally depolarize light (they scatter light, producing waves with differing orientations). Think about it - a polarizing filter absorbs 50% of unpolarized light. You wouldn't want a photo diffuser that cuts your light in half.
A cloudy sky works similarly. The water droplets scatter light randomly, yielding unpolarized light. A blue sky, on the other hand, produces polarized light. The blue color comes from the ozone layer which not only filters out the other colors, but also (because ozone molecules are electrically polarized) aligns the waves.
Reflection also affects polarization. Even if the source light is unpolarized, the reflection may be. Conversely, a polarized light can produce unpolarized reflections. Remember the 2 types of reflections, diffuse and direct? Well, diffuse reflections do not polarize light. In fact, they typically depolarize it. Direct reflections may or may not become polarized. Conductive surfaces (such as metal) typically reflect whatever light hits them neither polarizing nor depolarizing it. Non-conductive surfaces (including water, gloss plastic and polished wood) typically produce a polarized direct reflection.
Whew! That's a lot to get through. What's important to realize though is that glare can be be either polarized or unpolarized. If your light source is unpolarized, then glare off metal pen components will be unpolarized. Glare off a wood or plastic pen barrel, however, might be.
If the glare is polarized, then a polarizing filter can reduce or remove it. If the glare is unpolarized, however, then a polarizing filter will not. If the glare is mixed, then a polarizing filter could reduce it on one part but not another.
So, although a single polarizing filter on your camera lens might help control some glare, it is not a complete solution.
There is a technique called cross-polarization that some people use. In this setup, you place a polarizing filter over your light source. The diffuse reflections off your subject are depolarized. The direct reflections off your subject are polarized - even if they are metal. Now, a polarizing lens filter will remove the direct reflection (glare). Cross-polarization can work quite well, but it does have its own limitations. First off, it typically limits you to one light source (matching polarization can be difficult). Secondly, the polarizing filter halves your light, so to achieve the same exposure, you'll need a brighter (more expensive) light. The filter itself is an additional investment as well. Finally, some subjects will repolarize the direct reflection in multiple orientations, so there are still situations that cross-polarization will not handle.
Fortunately, there are tools to manage glare besides polarization. Since glare is really a matter of direct reflection - not polarization - then glare (polarized or unpolarized) can be controlled by manipulating the direct reflection. The angle (or "family of angles") of illumination that produces direct reflection is generally small compared to the angles that produce diffuse reflection. Therefore, you can control the glare by adjusting the relative brightness of the light(s) within that family of angles. If you want to reduce glare, you can selectively lower the proportion of light coming from the direction that produces direct reflection. Product photographers often use multiple lights and/or reflectors outside the family of angles of direct reflection, or place a "go-between" (a.k.a. "gobo") in front of a light blocking the family of angles that reduce glare.
That isn't as complicated as it may sound. Check out http://www.penturners.org/forum/f24/pen-photography-putting-concept-into-practice-128555/ for and example of using a light tent and a go-between to achieve a picture with even illumination and a subtle shine-line.
I hope that helps,
Eric
BJohn
Cabot, Arkansas
Whew that it also a lot to absorb, but Eric I for appreciate the information I have printed out all of you articles in the library and find them extremely interesting also.
Keep it coming.
Sylvanite
It has been said (in another thread):
I believe it is a bigger issue using a lite tent because of the tent Defuses or scatters the light causing the light to become polarized and then reflects the light inside the tent , which and again scatters the light causing the light to be polarized.
I'm sorry, but that is just plain wrong. Light tents do not polarize light. In fact, they depolarize it.
( Sorry )
Yes me too, I really don't care to disagree with someone who has great knowledge as yourself in the field of photograph .
I really don't care to disagree with anyone at any time or place..
I have a passion for photography just as you do too.
And wouldn't ( want ) to say anything that wasn't true or give advise that was bad.
Problem being is I believe in what I am saying and I have links to help prove what I am saying, plus I have done my own personal tests on photographing subjects with a smooth surface.
(Logic and common sense )
How does a light tent depolarize light ?
Not trying to bump heads but in all honesty the people who make polarized sunglasses would pay a fortune for that technology .
Light tents scatter light defusing or softening, and they reflect light '
and now you are saying they depolarize light ?
I have never read that......... please show me a company who makes light tents that claim there tents depolarize light ?
As you said just plain wrong and really not logical.
Light traveling at the speed it does travel at, crashing into the side of a light tent it would only be logical that the light at the point of being scattered could or would have some kind of static electricity or a electromagnetic wave or become polarized .
Rather than continue that discussion there, where it is off-topic, I've decided to address the issue here, as it may help clear up confusion about just what "polarization" is, and when it does and does not occur. So, in reply to:
  1. How does a light tent depolarize light ?
    The answer is simple. The light tent walls scatter the incoming light rays randomly, not only in direction (which is what diffuses the light), but also in polarity. The resulting light is diffuse and depolarized. Here's an experiment you can perform to confirm that the tent wall depolarizes light: Take 2 linear polarizing filters (you can use 2 CPL filters as well, but you must position them front-to-front). Hold them up in front of you and look at your source light. Now rotate one of the filters. You'll notice that as you rotate it, the image will turn black in one orientation, and gray at 90 degrees off. Now do the same thing, but with the two filters on opposite sides of a light tent wall (or any other photo diffuser). You'll see that as you rotate the filter, the light level does not change. That is because the tent wall / diffuser has depolarized the light.
  2. The people who make polarized sunglasses would pay a fortune for that technology.
    Sunglasses do not diffuse light. If they did, you wouldn't be able to see through them. Therefore the manufacturers don't care about the properties of diffusion. Polarized sunglasses serve two purposes. First (just like non-polarized sunglasses), they reduce the amount of light that passes through. Second, they block more light (up to all of it) provided that light is already polarized perpendicularly to the axis of the sunglasses. Now, it just so happens that the blinding reflection of sunlight off water is mainly polarized horizontally. Therefore polarized sunglasses (which polarize vertically) are quite effective at eliminating that glare. Glare, however, is not necessarily polarized. Polarized sunglasses do not, for example, cut the sun's glare off chrome bumpers. In that instance, polarized sunglasses are no better than non-polarized sunglasses.
  3. Light tents scatter light defusing or softening, and they reflect light and now you are saying they depolarize light?
    Yes. Of course a light tent reflects some light - otherwise it would appear black. Of course they diffuse light - that is their purpose. "Scatter" and "soften" are simply other ways of saying diffuse. I've explained the depolarization in answer 1 above.
  4. Please show me a company who makes light tents that claim there tents depolarize light ?
    I don't know of any photo diffuser (including light tents) manufacturer who makes any claim about polarization, so I can't show you one. I will turn the question around though. Can anybody show a company who claims that their photo diffuser (or light tent) polarizes light? I doubt one can be found, because (1) it is the nature of diffusion to depolarize light, and (2) if a diffuser did include a polarizing filter, it would cut the light transmission by at least half. That would certainly not be a desirable property.
  5. It would only be logical that the light at the point of being scattered could or would have some kind of static electricity or a electromagnetic wave or become polarized
    Smooth, non-conductive surfaces, such as water, gloss plastic, and highly polished wood do tend to produce polarized direct reflections. That is not, however the whole story. Conductive surfaces, such as polished metal, typically reflect light without changing the polarization (polarized light yields a polarized reflection; unpolarized light yields an unpolarized reflection). Both of those surfaces, as well as matte surfaces, also produce diffuse reflection. Diffuse reflection (because it is diffuse) is primarily depolarized. Think about it. If all these reflections were polarized, then a polarizing filter would not only filter out the glare, it would render the entire photograph black. The photographic technique of "cross polarization" only works because diffuse reflection (diffusion) depolarizes light.
Let's talk about nature's polarizing and depolarizing filters:
  • Blue sky. Ozone (O3) is an electrically polarized molecule. They tend to align with each other in the ozone layer, making it an electrically polarized filter in the sky. The size of the molecules selectively reflects light in the blue frequencies (while passing the reds) and the charge aligns the waves. That is why the sky is blue and why the blue light is polarized. Probably the most common photographic use of polarizing filters is to darken the blue sky, increasing contrast with the white clouds.
  • Overcast sky. Although the water molecule (H2O) is also electrically polarized, tiny water droplets (which is what clouds are formed of) are not. When light reflects off or passes through clouds, the droplets scatter (diffuse) the light in random polarization, yielding unpolarized light. That is why polarizing filters do not darken clouds in the sky photos I mentioned above. If you don't believe me, here's another experiment for you. On an overcast day, look up at the cloud layer through a polarizing filter. Rotate the filter and you'll see that the image remains equally bright. That indicates that the diffusion of the clouds produces depolarized light.
I hope that was helpful,
Eric
bobleibo
Utah
Eric
I really appreciate all the time you have put into these tutorials. I'm learning a lot thru them as I get the time to spend on what I have come to call your lesson plan, even if I only get to study a little bit at a time.
Thank you~
Bob
Sylvanite
How to tell if a light source is polarized
Here's an experiment you can perform to tell whether or not a light source is polarized:
  1. Set your camera to full manual exposure mode and mount a polarizing filter on the lens.
  2. Turn your source light on and place a linear polarizing filter (such as a pair of polarizing sunglasses) so that it partially obscures the light.
  3. Take a series of 4 photographs (all using the same exposure settings), rotating the camera's polarizing filter roughly 45 degrees each time.
If the light source is polarized, then you will see the image change in brightness noticeably - from white, to gray, to black, and back to gray (although not necessarily in that order).
If the light source is not polarized, it will be equally bright in all 4 photos.
The polarizing filter (sunglasses) serves as a control for the experiment. That part of the image will be polarized (whether the source is or not). You should see it change in intensity as you rotate the camera's polarizing filter.
Sylvanite
Proof that a CFL light bulb produces unpolarized light
I performed the above experiment with one of the CFL bulbs I use for pen photography. This is how the images changed as I rotated the camera's polarizing filter:
attachment.php
You can clearly see that the polarizing sunglasses changed in intensity dramatically. That part of the picture had polarized light. The rest of the light bulb, however, is bright in all 4 photos. The light bulb itself produces light that is NOT polarized.
Sylvanite
Proof that an incandescent light bulb produces unpolarized light
I performed the above experiment again, with an ordinary household incandescent light bulb. This image shows how the photographs changed as I rotated the polarizing filter:
attachment.php
As with the CFL test, the sunglasses indicate the effect a polarized light would produce. The bulb intensity, however, does not change. Therefore the light produced by the incandescent bulb is NOT polarized.
Sylvanite
To round things out, I tried again, this time with a household LED flood light. Here is the result:
attachment.php
Just as with the previous two experiments, the polarizing lens darkened as I rotated the camera's polarizing filter, but the bulb itself did not. The light given off by the LED bulb is NOT polarized.
mark james
IAP Collection, Curator
Medina, Ohio
Your series on Photography is incredible! These are a great asset for those in the membership that can utilize this guidance.
Thank you for your contribution.
farmer
NV
light
attachment.php
Eric in another thread you corrected me and said all light sources are polarized now you are say LED lighting isn't polarized if i understand this correctly?
If LED lighting isn't polarized maybe you retract your statement when you corrected me in another thread..
In one statement you said the sunglasses is linear polarized film.
I have to ask have you ever really worked with real Lineiar polarized film in photography ?
I have never done these tests that you are doing, but I have been working with linear polarized for a few years .
Truth is all the led lighting I looked up and studies said the LED lighting is polarized, At the same time i remember reading about LED light and it said it wasn't polarized.
So i geuss the best way is to figure all light sources is polarized light and the only way to get rid of polarized light is by filtering it.
Pens are round and you will always have a 90 degree light reflection even if the light is not polarized.
Light reflection
Polarized reflection
And UV reflections
It still seems to get down to if the light source is reflected, as its reflected inside the bulb.
If the light source is reflected like every light source known to man is polarized.
They say the suns light is not polarized , but i have done product photographs outside and using a light tent outside to and to be honest that's when i bought my first studio lighting continuous florescent lighting kit.
From my understanding the only way to depolarize light is to filter it.
How do you know those glasses are made with linear polarized film ?
I the only glasses i have seen that reminds my of polarized film is the cheap ones like the 3d glasses you get at the movie theater.
You want to do real tests then use real linear polarized film.
If you don't have any pm me your address and i will send some so your experiment will apples to apples Or 100 percent accurate because you are using the film some of the members here will be buying.
The real experiment is to do real product photographs, who cares what the light bulb looks like with or with out sunglasses over it.
What counts is the finish product.............
You know i use a Cross polarization technic in my product photography.
I might be the only one in here that is hitting my products with a extreme amount of light. 640 ws
If you look up polarization by scattering its clear at least to me that when light is scattered it becomes polarized.
To be honest the study of light is a little over my head.
I don't understand it all.
But I have been photographing exotic wood products with strobes and cross polarization.
Are my pictures coming out good or not.
I want members in here to really excel in there photography skills.
I don't care who is right or wrong as long as our advise is helping members just getting into photography.
i am going to be doing a thread very soon on Off shoe speed lighting on my picnic table .
(Single strobe ) or mono
I will be testing both with and with out linear film and a CPL.
PS
When light is polarized is scattered ( defused reflected or softened )It becomes polarized , see polarization by scattering.
farmer
NV
Just read this in a photography forum.
The weak colour is due to the LEDs, they don't provide a full colour spectrum, so won't render true colours, it'll be worse with red than any other colour.
Photography on the net
I quoted this out of a thread about photographing cars .
I thought some of you might be interested in this statement.
Farmer
Not much land D@m few cattle company
lorbay
BC. Canada
I would love to spend a week with Eric just to gain a little more than what is in my pea brain.
Lol
Lin
Sylvanite
To the best of my knowledge, I never said " all light sources are polarized". In fact, in the initial post of this thread, I said "Almost all light sources produce unpolarized light. That includes candles, the sun, and artificial lights (incandescent, fluorescent, and LED)". Please point me to the post you're referring to and I'll post a correction.
I have not myself used "polarized film" in photography, but I am familiar with linear polarizers, circular polarizers (which is a linear polarizer combined with a quarter-wave plate; it first polarizes linearly and then converts linear polarization to helical polarization) and with the technique of photographic "cross polarization". If you are not convinced that the sunglasses yield linear polarization, then please do try these tests yourself with linear polarizing film. I'm confident that the results will be the same.
Are you perhaps confusing LED light with LCD light? LCDs work by polarization. LEDs do not.
If "all light sources is polarized light" (sic) were true, then a polarizing filter, when aligned, would block all the light and the entire photo would be black - not just the glare. I'm sure you realize that it doesn't work that way.
Light reflection
And UV reflections
A light shining on a reflective cylinder will reflect some light at a 90 degree angle. (and every other angle from 0 to 180 degrees too). That reflection may or may not be polarized, and may or may not contain UV wavelengths. And if it does, so what?
Not true. The experiment photos above demonstrate that the light emitted from the bulbs (no matter how much they were reflected internally) is not polarized. Many (most) light sources "known to man" are NOT polarized.
Reflection does not necessarily polarize light. Sometimes it does; sometimes it does not. As I said earlier, diffuse reflection does not polarize light - it depolarizes it. Direct reflection off non-conductive surfaces generally does polarize light but direct reflection off conductive surfaces typically maintains its polarity (that is the reflection neither polarizes nor depolarizes the light).
That is correct. Direct sunlight is not polarized.
A polarizing filter does not depolarize light. It does the exact opposite. A polarizing filter absorbs light waves that are electrically perpendicular its axis of polarity. It passes light waves that are aligned with that axis. It will polarize un-polarized light. It will not depolarize polarized light. Diffusion will depolarize light Any scattering that randomly orients the light waves' polarity depolarizes light.
Polarizing sunglasses are linear polarizers - that is how they work. Whether or not they are constructed from "film" is irrelevant. Are you really claiming that polarizing sunglasses do not polarize light? If not, how do you think they work?
Polarizing sunglasses are real linear polarizers. The photos above demonstrate that. Specialty films will produce the same result.
I'll be getting to pen photos. I'm starting off with photos of the lights to dispel the myth that studio lamps produce polarized light.
The absolute amount of light is irrelevant. I've photographed pens using three monolights (totaling 600 ws) and using 2 26w CFL lights. Others here have posted pen photographs lit with only a flashlight. The only difference the absolute number of lumens makes is the shutter speed needed for proper exposure.
Polarization by air scattering does occur, but only at a specific and very small range of angles. All other angles do not produce significant polarization. The angles that produce polarization do not typically occur in studio photography (I've never seen it at all).
By means of analogy, rainbows are produced by refraction through atmospheric water at a certain angle. Saying that all light that that is diffused or reflected becomes polarized is like saying that all light that that is refracted becomes rainbows. Practical observation, however, clearly shows that neither is assertion is true.
I also want to help people improve their photographic skills. That's why I'm spending so much time and effort trying to correct misinformation.
Please do perform the above experiments for yourself. You don't even need to use the polarizing film. The sunglasses are just there to demonstrate that the Circular Polarizing Filter on the camera was doing its job. Put a CPL filter on your lens, and look through the viewfinder at your light source while rotating it. If the light source is polarized, your image will at some point turn black. If turning the filter doesn't change the intensity, then the light isn't linearly polarized.
Again, the scattering that can cause polarization occurs at a very small range of angles that simply are not encountered in studio photography. It's a mistake to read "can be polarized at one angle" as "is always polarized at all angles".
Sincerely,
Eric
Sylvanite
Some light sources ARE polarized
I've shown three light sources (fluorescent, incandescent, and LED) that produce unpolarized light. Now here's one that is polarized:
attachment.php
This is the LCD screen on a tablet. Note that as the cameras polarizing filter (CPL in this case) is rotated, that the screen brightness changes as well as the brightness as seen through the polarizing sunglasses. That demonstrates that the light emitted by the LCD display is linearly polarized.
Now, we don't often use LCD lighting for pen photos, but people have posted pen photos taken on a LCD background. See http://www.penturners.org/forum/f24/unusual-small-item-photography-setup-94007/ for an example. If one tried to use a CPL filter to control glare on a pen sitting on such a background, unexpected results might occur.
Note, not all LCD displays exhibit this phenomenon. My LCD TV, for example, does not. I believe that's because it incorporates a form of quarter-wave plate over the LCD layer. That changes the linear polarization to helical (or "circular") polarization (just like a CPL filter does for a camera - although for a different purpose).
farmer
NV
photography
Quote Eric
Straight up I will send you some polarized film as long as You don't need a big piece ..........................
I have never used Linear polarized film on anything except flash or strobe lighting.
I would prefer that tests or experiments that we do can be done with the linear polarized film that is used in photography..
I am getting ready to shut down for the evening,
I will read the rest of everything you wrote.
I also will have to crack the books open and start looking things back up on line.
I will do my best to either post links or page numbers of the same book we both own.
I don't know how you can do a accurate and honest tests on reflection and linear polarized film in photography when you don't own any linear polarized film.
This is not a dig, but to keep things simple and this thread is about polarization and reflection you need some linear polarized film.
Or you need a big pair of sun glasses that will fit or cover one or more of your lights.
Sylvanite
So far, I've posted no tests on reflection. So far, I have not said my tests were with polarized "film". I have used polarizing sunglasses. Polarized film and polarizing sunglasses are both examples of linear polarizers.
And, in the experiments I've posted above, the polarizers are just the control, not the test. All the sunglasses do is verify that the CPL orientation is different in each individual photograph. The actual test is that the brightness of the un-obscured portion of the light bulb did not vary as I rotated the CPL filter. You're objecting to the wrong part of the experiment.
The tests certainly CAN be done with any linear polarizer - including linear polarizing film. In fact, they can be done without any linear polarizer at all - just the CPL filter on the camera lens. I encourage you to try it for yourself.
Then do the experiment with your monolight. I'm sure you'll find that it produces light that is not polarized (with or without the softbox). Think about it - if the strobe, the softbox reflector, or the softbox cover (diffuser) did indeed polarize the light, then you wouldn't need the polarizing film at all.
Sylvanite
Proof that polarizing sunglasses are a Linear Polarizing Filter
I set up the following 4 photos (combined into one image) to demonstrate that the pair of polarizing sunglasses that I'm using is indeed a linear polarizing filter:
attachment.php
Image 1, in the upper left corner:
In this photograph, I've arranged two photographic linear polarizing filters with a little bit of space between them. The rear one is turned to block light that is vertically polarized. The front one is turned to block light that is horizontally polarized. Where they overlap, they block all light. The card behind them is lit with unpolarized light.​
Image 2, in the upper right corner:
Here, I've place the polarizing sunglasses in between the two photo filters, oriented horizontally. You can see that this matches the polarizing angle of the front filter. Where it overlaps the rear filter, the image is black.​
Image 3, in the lower left corner:
In this photo, the sunglasses are between the photo filters, but oriented vertically. This matches the polarizing angle of the rear filter. Where it overlaps the front filter, the image is black.​
Image 4, in the lower right corner:
And, finally, I've oriented the sunglasses (still between the photo filters) at an angle. Now it does not match the polarizing angle of either filter. The area where it overlaps both filters is now transparent (although dark). You can read the ad (where it says "Nikon") that was blacked out in photos 1-3. This effect may seem counter-intuitive (after all, how is it possible that an additional filter could unblock light?), but it is real. The rear filter converts unpolarized light into vertically polarized light (dimming it in the process). The middle filter (the sunglasses) converts the vertically polarized light into light polarized at a 45 degree angle, and dims it further. The front filter converts the 45 degree polarized light into horizontally polarized light (and dims it yet again). Although each filter reduces the amount of light transmitted, some does indeed get through.​
A non-polarizing neutral density filter will not produce the above results. It won't totally black out areas overlapped with a single polarizer like photos 2 and 3 do. A circular polarizing filter will not produce the above results. It will undo the linear polarization of one of the two outside filters (which one depends on which way the CPL is facing), yielding a result that is the same as using just 2 linear polarizing filters. Quarter-wave plates can be combined to rotate polarized light by 90 degrees, but not 45 degrees as the sunglasses did in photo 4.
Only a linear polarizing filter will produce the effects shown above. Therefore, the sunglasses' lenses are true linear polarizing filters. They aren't "made for photography", but they work exactly the same way as a photographic linear polarizing filter does.
If you happen to have 3 photographic linear polarizing filters, or 2 CPL filters and one PL (you just have to put the CPLs on the outside and face-to-face), or 3 pieces of linear polarizing film, you can easily perform this experiment for yourself.
I hope that helps,
Eric
farmer
NV
UN real
Just got done putting in a couple hrs on a reply and my internet stopped working and lost everything.'
What a waist of time ..
Sylvanite
Proof that a light tent does not polarize light.
Ok, enough about the polarity of various light sources. It has been said that diffusion of light polarizes it; that simply passing through a light tent will polarize light. Here's a set of photographs showing that it isn't so:
attachment.php
The above 4 images show an illuminated light tent wall photographed through a circular polarizing (CPL) filter rotated in (roughly) 45 degree increments. Each one was taken with the same exposure. You can plainly see that the tent wall (the white background) luminosity remains constant.
If the diffuser (tent wall) had polarized the light, then it would have darkened to black, just like the polarizing sunglasses lens did (in the photo in the lower left corner). The angle of the CPL, howevver, made no difference. Therefore, diffusion in general, and a light tent wall in specific, does NOT polarize light.
Sylvanite
Proof that a light tent actually depolarizes light.
I've claimed in the past that not only does diffusion not polarize light, that in actually de-polarizes it. Here is an image to support that assertion. I placed a linear polarizing filter (polarizing sunglasses again) immediately behind my light tent wall, through a pair of openings in the front.
attachment.php
As before, these four photos were shot at the same exposure with a circular polarizing (CPL) filter on the camera lens rotated in approximately 45 degree increments. You can see that as I changed the polarization axis of the filter, the exposed part of the sunglasses turned dark - all the way to black. The covered areas, however, did not change in intensity. There is a shadow showing, but it is pretty constant in all 4 pictures. If the light tent wall passed light without affecting polarity, then the area covering the sunglasses would have turned black along with the unobscured lens (lower left photo). If the tent wall had changed the polarity, then one of the other 3 photos would have turned black (or at least much, much darker). They didn't.
Because the light striking the inside of the tent wall was polarized (by the sunglasses), but the light exiting from the tent wall was not, I conclude that the light tent (via diffusion) depolarized the light.
farmer
NV
What cause light to be polairized
There are 4 things that cause light to be polarized.
So if any of use do any of these four things to the light we are using in our pen photography you have polarized light and polarized reflection in your pictures.
It is possible to transform unpolarized light into polarized light. Polarized light waves are light waves in which the vibrations occur in a single plane. The process of transforming unpolarized light into polarized light is known as polarization. There are a variety of methods of polarizing light. The four methods discussed on this page are:
Polarization by Transmission
Polarization by Reflection
Polarization by Refraction
Polarization by Scattering
The question is, is the light you are using in your photography is polarized or un-polarized when the light strikes the pen or the smooth surfaced nonmetallic subject.
First off we must ask is the light we are using emitting electromagnetic polarized waves before we soften or defuse the light.
Most lighting is not polarized ( Note I didn't say all lighting )
But Florescent lighting is polarized light which isn't a big deal considering that by time any of us get done defusing the light source and by time the light strikes the pen its polarized.
But first lets prove that florescent lighting is electromagnetic polarized light..............
Well wiki says florescent lighting is polarized !
https://en.wikipedia.org/wiki/Fluorescence_anisotropy
Fluorescence anisotropy is the phenomenon where the light emitted by a fluorophore has unequal intensities along different axes of polarization. Early pioneers in the field include Aleksander Jablonski, Gregorio Weber,[1] and Andreas Albrecht.[2] The principles of fluorescence polarization and some applications of the method are presented in Lakowicz's book.
I see no reason to debate if florescent lighting is polarized light or un polarized any more, it clearly states that florescent lighting is polarized ...
Next as photographer are we making the light we use polarized ?
Well if you are doing the following things then you may not know it regard less of what lighting you are using.
But in most cases I would have to say that everyone in here is using polarized light inless you are doing bare bulb photography
and here is my proof.
You guys might really want to read this because color is involved in this too............
Polarization
.ad3Container{margin-top:10px;}.adslot_3{width:320px;height:100px;}@media (min-width:992px) {.adslot_3{width:728px;height:90px;}}@media (max-width:640px) {.ad3Container{display:block;left:0;position:absolute;top:-740px;width:100%;}.adslot_3{display:block!important;height:100px;margin-left:auto;margin-right:auto;text-align:center;width:320px;}.navbar .container{padding-top:80px;}#bannerHolder>img{height:75px;}}
Polarization
Light Waves and Color - Lesson 1 - How Do We Know Light is a Wave?
Polarization
A light wave is an electromagnetic wave that travels through the vacuum of outer space. Light waves are produced by vibrating electric charges. The nature of such electromagnetic waves is beyond the scope of The Physics Classroom Tutorial. For our purposes, it is sufficient to merely say that an electromagnetic wave is a transverse wave that has both an electric and a magnetic component.
The transverse nature of an electromagnetic wave is quite different from any other type of wave that has been discussed in The Physics Classroom Tutorial. Let's suppose that we use the customary slinky to model the behavior of an electromagnetic wave. As an electromagnetic wave traveled towards you, then you would observe the vibrations of the slinky occurring in more than one plane of vibration. This is quite different than what you might notice if you were to look along a slinky and observe a slinky wave traveling towards you. Indeed, the coils of the slinky would be vibrating back and forth as the slinky approached; yet these vibrations would occur in a single plane of space. That is, the coils of the slinky might vibrate up and down or left and right. Yet regardless of their direction of vibration, they would be moving along the same linear direction as you sighted along the slinky. If a slinky wave were an electromagnetic wave, then the vibrations of the slinky would occur in multiple planes. Unlike a usual slinky wave, the electric and magnetic vibrations of an electromagnetic wave occur in numerous planes. A light wave that is vibrating in more than one plane is referred to as unpolarized light. Light emitted by the sun, by a lamp in the classroom, or by a candle flame is unpolarized light. Such light waves are created by electric charges that vibrate in a variety of directions, thus creating an electromagnetic wave that vibrates in a variety of directions. This concept of unpolarized light is rather difficult to visualize. In general, it is helpful to picture unpolarized light as a wave that has an average of half its vibrations in a horizontal plane and half of its vibrations in a vertical plane.
The way I understand this if you are doing any one of the 4 ways to polarized light in your photography then you have polarized light.
Personally if I understand all this correctly I am doing all four in my photography .
But lets go though this one at a time.
Polarization
Polarization by Use of a Polaroid Filter
The most common method of polarization involves the use of a Polaroid filter. Polaroid filters are made of a special material that is capable of blocking one of the two planes of vibration of an electromagnetic wave. (Remember, the notion of two planes or directions of vibration is merely a simplification that helps us to visualize the wavelike nature of the electromagnetic wave.) In this sense, a Polaroid serves as a device that filters out one-half of the vibrations upon transmission of the light through the filter. When unpolarized light is transmitted through a Polaroid filter, it emerges with one-half the intensity and with vibrations in a single plane; it emerges as polarized light.
A Polaroid filter is able to polarize light because of the chemical composition of the filter material. The filter can be thought of as having long-chain molecules that are aligned within the filter in the same direction. During the fabrication of the filter, the long-chain molecules are stretched across the filter so that each molecule is (as much as possible) aligned in say the vertical direction. As unpolarized light strikes the filter, the portion of the waves vibrating in the vertical direction are absorbed by the filter. The general rule is that the electromagnetic vibrations that are in a direction parallel to the alignment of the molecules are absorbed.
The alignment of these molecules gives the filter a polarization axis. This polarization axis extends across the length of the filter and only allows vibrations of the electromagnetic wave that are parallel to the axis to pass through. Any vibrations that are perpendicular to the polarization axis are blocked by the filter. Thus, a Polaroid filter with its long-chain molecules aligned horizontally will have a polarization axis aligned vertically. Such a filter will block all horizontal vibrations and allow the vertical vibrations to be transmitted (see diagram above). On the other hand, a Polaroid filter with its long-chain molecules aligned vertically will have a polarization axis aligned horizontally; this filter will block all vertical vibrations and allow the horizontal vibrations to be transmitted.
Polarization of light by use of a Polaroid filter is often demonstrated in a Physics class through a variety of demonstrations. Filters are used to look through and view objects. The filter does not distort the shape or dimensions of the object; it merely serves to produce a dimmer image of the object since one-half of the light is blocked as it passed through the filter. A pair of filters is often placed back to back in order to view objects looking through two filters. By slowly rotating the second filter, an orientation can be found in which all the light from an object is blocked and the object can no longer be seen when viewed through two filters. What happened? In this demonstration, the light was polarized upon passage through the first filter; perhaps only vertical vibrations were able to pass through. These vertical vibrations were then blocked by the second filter since its polarization filter is aligned in a horizontal direction. While you are unable to see the axes on the filter, you will know when the axes are aligned perpendicular to each other because with this orientation, all light is blocked. So by use of two filters, one can completely block all of the light that is incident upon the set; this will only occur if the polarization axes are rotated such that they are perpendicular to each other.
A picket-fence analogy is often used to explain how this dual-filter demonstration works. A picket fence can act as a polarizer by transforming an unpolarized wave in a rope into a wave that vibrates in a single plane. The spaces between the pickets of the fence will allow vibrations that are parallel to the spacings to pass through while blocking any vibrations that are perpendicular to the spacings. Obviously, a vertical vibration would not have the room to make it through a horizontal spacing. If two picket fences are oriented such that the pickets are both aligned vertically, then vertical vibrations will pass through both fences. On the other hand, if the pickets of the second fence are aligned horizontally, then the vertical vibrations that pass through the first fence will be blocked by the second fence. This is depicted in the diagram below.
In the same manner, two Polaroid filters oriented with their polarization axes perpendicular to each other will block all the light. Now that's a pretty cool observation that could never be explained by a particle view of light.
I use a linear polarized filter on my strobes so a can only assume if I understand what was said above that in this cause I am actually polarizing the light.
Funny I didn't know that part , but I am using a cross polarization technic that my CPL will filter out polarized waves.
part 1 of 1
farmer
NV
Part two, are we polarizing
The second way to polarize light is.
Unpolarized light can also undergo polarization by reflection off of nonmetallic surfaces. The extent to which polarization occurs is dependent upon the angle at which the light approaches the surface and upon the material that the surface is made of. Metallic surfaces reflect light with a variety of vibrational directions; such reflected light is unpolarized. However, nonmetallic surfaces such as asphalt roadways, snowfields and water reflect light such that there is a large concentration of vibrations in a plane parallel to the reflecting surface. A person viewing objects by means of light reflected off of nonmetallic surfaces will often perceive a glare if the extent of polarization is large. Fishermen are familiar with this glare since it prevents them from seeing fish that lie below the water. Light reflected off a lake is partially polarized in a direction parallel to the water's surface. Fishermen know that the use of glare-reducing sunglasses with the proper polarization axis allows for the blocking of this partially polarized light. By blocking the plane-polarized light, the glare is reduced and the fisherman can more easily see fish located under the water.
I know that when I soften light in side my soft box which is allot like a lite tent inside I am creating polarizing light be cause I am reflecting it.
From this point I see no reason to debate if we reflect un polarized light will it become polarized or not.It clearly states above that it does.
End or part 2
farmer
NV
Part 3 of what polarizes light
Polarization can also occur by the refraction of light. Refraction occurs when a beam of light passes from one material into another material. At the surface of the two materials, the path of the beam changes its
direction. The refracted beam acquires some degree of polarization. Most often, the polarization occurs in a plane perpendicular to the surface. The polarization of refracted light is often demonstrated in a Physics class using a unique crystal that serves as a double-refracting crystal. Iceland Spar, a rather rare form of the mineral calcite, refracts incident light into two different paths. The light is split into two beams upon entering the crystal. Subsequently, if an object is viewed by looking through an Iceland Spar crystal, two images will be seen. The two images are the result of the double refraction of light. Both refracted light beams are polarized - one in a direction parallel to the surface and the other in a direction perpendicular to the surface. Since these two refracted rays are polarized with a perpendicular orientation, a polarizing filter can be used to completely block one of the images. If the polarization axis of the filter is aligned perpendicular to the plane of polarized light, the light is completely blocked by the filter; meanwhile the second image is as bright as can be. And if the filter is then turned 90-degrees in either direction, the second image reappears and the first image disappears. Now that's pretty neat observation that could never be observed if light did not exhibit any wavelike behavior.
Watch It!
In the demonstration below, the word PHUN (as in Physics is ...) is written on the glass panel of a classroom-style overhead projector. A sample of Iceland spar is placed over the word PHUN. Two images of the word PHUN can be faintly seen in the early seconds of the movie. The crystal double refracts light that passes through it. At about the 8-second mark, a Polaroid filter is placed over the crystal and rotated. As it rotates, the two images alternately fade in and out. The light passing through the crystal becomes polarized and when the Polaroid filter is rotated, it blocks and transmits the two light paths in alternating fashion. The result is that the two images of PHUN can be seen one at a time. Pretty cool stuff!
I am not sure on this one, some of my products have a thick looking clear finish on them and I am not sure if that would be considered refraction ?
Part 3 of 4
farmer
NV
Part 4 of how to polarize light.
And they say the sun light is not polarized .:rolleyes:
Polarization also occurs when light is scattered while traveling through a medium. When light strikes the atoms of a material, it will often set the electrons of those atoms into vibration. The vibrating electrons then produce their own electromagnetic wave that is radiated outward in all directions. This newly generated wave strikes neighboring atoms, forcing their electrons into vibrations at the same original frequency. These vibrating electrons produce another electromagnetic wave that is once more radiated outward in all directions. This absorption and reemission of light waves causes the light to be scattered about the medium. (This process of scattering contributes to the blueness of our skies, a topic to be discussed later.) This scattered light is partially polarized. Polarization by scattering is observed as light passes through our atmosphere. The scattered light often produces a glare in the skies. Photographers know that this partial polarization of scattered light leads to photographs characterized by a washed-out sky. The problem can easily be corrected by the use of a Polaroid filter. As the filter is rotated, the partially polarized light is blocked and the glare is reduced. The photographic secret of capturing a vivid blue sky as the backdrop of a beautiful foreground lies in the physics of polarization and Polaroid filters.
In photography personally I consider all light to be polarized.
OK I am done, I have stated my case, you guys can go about your photography the way you want to.
If you think the light you are using inside a light tent using florescent lighting is un - polarized then go ahead .
But the truth is the light inside a lite tent actually is polarized and the above links 100 percent prove it...............
This may not be important but in reading all this I found out that Electromagnet polarized waves will travel through walls ..........................
Sylvanite
Well, the real question is whether or not the light reaching the camera is polarized, not whether or not the source light is, but the two are sometimes related, so to understand what's happening at the camera, you have to understand the light source.
Most pens we make have both metallic and nonmetallic components. Reflective polarization behaves differently with conductive and non-conductive surfaces, so you need to consider more than just the nonmetallic parts.
Ok.
True.
Not true.
... by time any of us get done defusing the light source and by time the light strikes the pen its polarized.
Not true.
You are making the same mistake you made with polarization by scattering. That is, you're reading something that says a phenomenon can occur under some circumstances, and taking it to mean that....................... the phenomenon occurs under all circumstances. That is incorrect.
Fluorescence anisotropy, in this case, occurs specifically when the fluorescing material is excited by polarized light. When that occurs, the fluorescent light emitted is partially polarized. If, however, the fluorescing material is excited by unpolarized light, then it produces unpolarized light. The fluorescent light bulbs that we commonly use generate unpolarized UV light to excite the fluorescing material (the white coating on the inside of the bulb) which then emits unpolarized visible light.
Again, it does not state that all fluorescent light is polarized. It states that under very specific circumstances (which are not the circumstances we see in pen photography), that fluorescent light can be partially polarized. You are over-generalizing.
I'm sorry. I see a large quote copied from another site, but I don't see a proof.
Again, these are ways in which light can become polarized. It does not mean that each one of them always will polarize light. It is entirely possible to (1) transmit, (2) reflect, (3) refract, and (4) scatter light without polarizing it.
Once more, I see a large quote taken from another website, but no other explanation.
Yes. The strobe emits unpolarized light. The silver lining in your softbox reflects unpolarized light. The diffusing screen on the front of your softbox scatters unpolarized light. The linear polarizing film you hang over the softbox is what polarizes the light.
Think about it, if it were true that the flash, reflector, or diffuser polarized light, then you wouldn't need the polarizing film at all.
Ok, I'm confused. How can you use cross-polarization in photography without knowing that linear polarizing film polarizes light?
And, the way you say that makes me wonder if you realize that a CPL (circular polarizing) filter doesn't simply "filter out polarized waves". It actually is a linear polarizing filter which polarizes the light in exactly the same way as the polarizing film does. From a photographic effect standpoint, a linear polarizing (PL) filter is no different than a circular polarizing (CPL) filter. The CPL filter simply has another layer on the back that converts the linear polarized light into helical (circular) polarized light. This has no effect on the image that a camera sensor (or film) records, but eliminates problems in auto-focus and light metering that polarized light may cause.
I suggest you go back and reread the source you just quoted, and pay particular attention to statements like:
"Unpolarized light can also undergo polarization by reflection off of nonmetallic surfaces." and
"Polarization can also occur by the refraction of light"
Note that they say "can", not "always does". Note also that it specifically says says "nonmetallic" surfaces. That should indicate to you that metallic reflections do not polarize light. Note that the example they give for polarization by refraction uses a "unique crystal... Iceland Spar, a rather rare form of the mineral calcite". That should tip you off that polarization by refraction is not an everyday occurrence.
The article you quoted (while not entirely complete) is accurate, but you are reading more into it than is there.
Regards,
Eric
Sylvanite
Not true.
Read what you just quoted again. It says:
  1. "Unpolarized light can also undergo polarization by reflection off of nonmetallic surfaces. "
    Note that it says "CAN", not "ALWAYS DOES". Reflection does not always yield polarization.
  2. "The extent to which polarization occurs is dependent upon the angle at which the light approaches the surface and upon the material that the surface is made of."
    Note that polarization is angle dependent. Only reflections at some angles become polarized. Reflection at most angles does not polarize light.
  3. "Metallic surfaces reflect light with a variety of vibrational directions; such reflected light is unpolarized."
    This clearly says that metallic surfaces do not polarize light. Take a look at the reflector in your softbox. I think you will most likely find that it is metalized (silvered - although probably with aluminum). The metallic surface will not polarize light at any angle.
If you take a moment to perform a simple test, such as I have shown above, you can easily determine whether or not your softbox polarizes light.
And, I'll ask again, if you believe that your softbox does polarize light, then why do you bother putting a polarizing film over it?
Sylvanite
Look again at the text you just quoted. It says:
"Polarization can also occur by the refraction of light."
It says "CAN", not "ALWAYS DOES".
The circumstances under which refraction polarizes light are atypical. That is why they have to resort to a "unique crystal... Iceland Spar, a rather rare form of the mineral calcite" to demonstrate the effect. I doubt you'll ever encounter significant polarization from refraction in a studio photography environment.
Think about it, a camera lens works by refraction. If that refraction always polarized the light, then why would you bother putting a CPL (rather than just a PL) filter on your lens? The refraction polarization would undo the circular polarization. No, the reason you use a CPL rather than a PL filter is that the linear polarization produced by the PL persists through the refraction of the lens, and might interfere with a camera's light meter or auto-focus sensor.
walshjp17
Weddington, NC
Eric,
You should take all your excellent tutorials on pen photography and put them in a book. I'm sure between IAP and FB you could find a ready market.
Sylvanite
Direct sunlight is not polarized. Here's a simple experiment you can perform in a spare moment to demonstrate that:
Take a piece (it doesn't have to be very big) of your photographic linear polarizing film outside on a sunny day and hold it such that you can see its shadow. Now rotate it slowly through 180 degrees. If the sunlight is polarized, you'll see the shadow disappear completely when the film's axis of polarization aligns with the sun's polarization, and the shadow will darken to black when the film's axis is perpendicular to the sunlight's. If the shadow does not lighten and darken as you rotate the film, then the sunlight does not have an axis of polarization - and therefore is not polarized.
Don't just read about it. Try it for yourself.
I did it just now with a photographic polarizing filter. As I rotated the filter, the shadow stayed the same shade of gray.
Then you're wrong. I ask again, if all light is polarized, then why do you use polarizing film?
Yes, I believe that the light inside a light tent illuminated with fluorescent lights is unpolarized - and I've posted a series of photographs that demonstrate that fact above.
No, it isn't, and no the links don't prove it. The fact that light CAN BECOME polarized does not mean that it ALWAYS IS polarized. In logical terms, you are attempting proof by example, which is fallacious.
Atmospheric, or "Rayleigh" scattering (I know you know the name, because you quoted it previously) is only significant, and only polarizes light at angles approaching 90 degrees to the light source. The effect is visible in the sky, but not in studio photography. We don't illuminate our subject by pointing the studio light at the air beside it.
So, if as you say:
  1. "I consider all light to be polarized", and
  2. "Electromagnet polarized waves will travel through walls", therefore
  3. All light passes through walls
then you've just 100 percent proven that all walls are completely transparent - despite any examples to the contrary. Is that true?
farmer
NV
Light
Regardless if the light source is polarized or un polarized I have soft boxes on my strobes, < Polarization by Reflection > I soften my light, the light that is going through my soft boxes is being polarized because its being reflected and scattered ...Polarization by Scattering.
Then the light is filtered Polarization by Transmission which is really is separating the light.
The word polarize means to separate!, therefor the light that strikes the pen is polarized light.......................................
The only one out of the four I missed is Polarization by refraction.
Yes the suns light is partially polarized
Sylvanite
Ok.
Not so. While reflection and atmospheric scattering CAN polarize light, they DO NOT ALWAYS polarize light. The reflection inside the light box and the diffusion of the front screen are instances that DO NOT polarize light.
  1. Can you take a photograph demonstrating that your softbox emits polarized light?
  2. Can you explain why none of the photos in POST 20 - "Proof that a light tent does not polarize light" darkened if diffusion polarizes light?
I challenge you to do so.
Then the light is filtered which is really is separating the light.
The word "separate" is not synonymous with "polarize" I can think of multiple ways to separate light without polarizing it. Restating a false premise in different words does not make it true.
Actually, you didn't. Your camera lens refracts light.
  1. Did you perform the experiment I described in POST 30? If not, please do. If so, did the shadow disappear (lighten) and darken as you rotated the film? If not, explain why not.
  2. If, as you say, the reflection and diffusion inside the softbox polarize the light, then why do you bother putting polarizing film over it? The light exiting the softbox would already be polarized.
  3. If the air in between the polarizing film and the subject polarize the light, then why did you need to use polarizing film before that?
  4. If all the reflection off the subject is polarized, then why bother polarizing the light that hits the subject?
  5. If the air in between the subject and the camera lens polarizes the light, then why doesn't rotating the CPL filter opposite to its axis of polarization block all the light, and turn the image black?
  6. If the refraction of the lens elements polarizes the light, then why did you bother using a CPL filter, rather than a plain PL filter on your lens? Ditto for polarization by scattering of the air between the lens elements and in front of the sensor.
I challenge you to logically answer the above six questions. And please give your explanation -- don't just copy text from another website and claim it supports your assertions.
Consider this quote (also from physicsclassroom.com):
Rainbow Formation: A collection of suspended water droplets in the atmosphere serves as a refractor of light. The water represents a medium with a different optical density than the surrounding air. Light waves refract when they cross over the boundary from one medium to another. The decrease in speed upon entry of light into a water droplet causes a bending of the path of light towards the normal. And upon exiting the droplet, light speeds up and bends away from the normal. The droplet causes a deviation in the path of light as it enters and exits the drop.
Using the same logic you employed to describe polarization:
  1. Rainbows are caused by the refraction of light waves.
  2. Each of the elements in a camera lens refracts light waves.
  3. Therefore they must each produce a rainbow.
  4. That proves 100 percent that every photograph ever taken must have at least one rainbow in it somewhere.
That conclusion is equally as valid, and just as incorrect as those you have made about polarization.
farmer
NV
Polaized light
Answering your 6 questions.
1#Did you perform the experiment I described in POST 30? If not, please do. If so, did the shadow disappear (lighten) and darken as you rotated the film? If not, explain why not.
Answer
No, I don't trust your experiments and I am not photographing sun glasses in a test when the lenses in sunglasses are not just linear polarized film, there is another thin film that goes over the linear polarized film used in sunglasses just for humans. This why I offered you Linear polarized film LPF used in photography, I said in the beginning I wanted to use LPF that was used in product photography and production sets like TV .
SEE 3D Movie glasses and sun glasses design.
#2 If, as you say, the reflection and diffusion inside the softbox polarize the light, then why do you bother putting polarizing film over it? The light exiting the softbox would already be polarized.
Answer
First its not me saying it, I am only repeating what it says about what causes polarization, that is why I have posted the link to polarization by reflection a half dozen times.
If you don't like what I am repeating then take it up with the experts.
Send comments to Wiki prove it to them.
Because I put my trust into someone who has to stand accountable in front of the science community, and we are not professors in anything.
Putting Linear polarized film (LPF) over my soft boxes is the only place you can place it to get a cross polarization.
If I put the film inside the soft box the defuse panel ( white cloth ) over it.
It would create polarized waves to travel at more then just a linear motion.
farmer
NV
PT 2 of answering questions
Your Question
#3
My answer
LOL didn't we just go through this in question number 2 ?
# 4
This is getting weird its the same question asked in three different ways.
I answered this question 2 questions ago.
#5
My answer
The only way to polarize light between the camera and the subject would be if the light was colliding with something in the air.
Under those conditions I do not think I will be doing product photography on pens.
Reason being the only thing I can think of the would polarize the light would be dust .
And dust and product photography doesn't mix.
When the suns light finally strikes earth the light has been reflected off of space dust and that is why the suns light is partially polarized and our shy is blue.
Your talking polarization by scatting out of context ..
Thank God its Friday and this is the last questing :biggrin:
QUESTION # 6
I don't know, your the one who said lenses refract light and creates polarization inside the lens .
It could be the truth ? my TSE 17mm lens has over a dozen pieces of glass inside.
The way understood it the Polarization by refraction laws
Is the light passes through something like glass then strikes a subject like our pen.
Because of the smooth non metallic surface that is where the reflection or glare is seen.
As far as I know humans don't see polarized light until is strikes a smooth non metallic surface like a pen.
Sylvanite
Answer
Well, you've made it abundantly clear that you object to polarizing sunglasses (even though I demonstrated that they are linear polarizing filters exactly like those used in photography (which are by the way, different than 3D polarizing glasses). That is why I:
  1. performed the test you reference above with a photographic linear polarizing filter, and
  2. asked you to perform the experiment with your linear polarizing film
If you still refuse to try it out for yourself, then go ahead and send me some film. I'll repeat some experiments using it on one condition: that you agree to accept the results.
Answer
That is not an answer, it is an evasion. I'll ask again. If your expert tells you that your softbox emits light that is already polarized, why do you put a polarizing filter over it. At best, it would be redundant. At worst, it would block the light completely.
What motion would it create? You insist that the polarizing film and the diffuser both polarize light. Why use both?
Sylvanite
#3
My answer
No. Question 2 was about "polarization by reflection". This question is about "polarization by scattering". You said that all light that passes through air is polarized. If so, why do you need to polarize the light before that?
# 4
No, this question is about reflection off the subject (pen), not reflection within your softbox. you said that all reflection polarizes light. If the pen reflection polarizes light, why did you need to polarize the light beforehand?
#5
My answer
Space dust? Really? Where on physicsclassroom.com does it say anything about "space dust"? You said that light was polarized by "colliding with the air", not by colliding with dust. How is the air in your studio between the light and the subject any different than the air directly between the sun and the object lit it? Not lit by the sky, but lit by direct sunlight?
# 6
No, you are the one who claims that all refraction polarizes light. See your statements on "polarization by refraction".
Ok, if you believe that the elements in your lens polarize light, then why do you bother putting a CPL filter (rather than a PL filter) on your lens. Wouldn't the "polarization by refraction" create the exact problem that you use a CPL filter to prevent?
How is the glass before the pen different than the glass after the pen?
What about the smooth metallic surfaces of the pen? Reflection and glare are seen there too. How do you explain that? Do you:
  1. Insist that reflection off metal polarizes light, or
  2. Admit that not all reflection polarizes light?
Are you saying that polarized light isn't visible? It is. The eye sees all light in the visible spectrum -- whether it is polarized or not. Humans just can't differentiate whether or not light is polarized nor the orientation of polarization (if any).
Sylvanite
So what does polarization have to do with pen photography?
I imagine that most readers are getting pretty tired of following this argument (which I agree has gotten quite tedious) and are wondering what all this esoteric information has to do with actual pen photography.
Well, I've decided to get the subject back on track. I'll be making a series of individual posts, each of which will illustrate an aspect of polarization and/or glare with real pen photos. I hope that they will further people's understanding of lighting, reflection, glare, and polarization in a way that helps them take better pictures.
Before I start, however, let me go over a few basics again.
  • Source light may be either polarized or unpolarized (photo studio lights produce unpolarized light; filters can be used to polarize it).
  • Reflections can, under some circumstances, polarize light. Under other circumstances, reflections can depolarize light. And, some reflections neither polarize nor depolarize light. Which of these happens depends on the conductivity of the object, its surface texture, and the angle of reflection. I'll be giving specific examples in future posts.
Physicists may tell you that there is but one law of reflection: "angle of incidence = angle of reflection", but photographers often divide reflection into two categories:
  • Direct reflection occurs when the surface reflects light solely at the complementary angle (as in the formula above). Direct reflection may or may not polarize light.
  • Diffuse reflection occurs when the surface scatters or diffuses the light. That is, the surface texture reflects light at a range of angles beyond the angle of incidence. Diffuse reflection typically depolarizes light.
Most subjects produce a combination of direct and diffuse reflection, although some can produce one or the other almost exclusively. Mirrors, for example, produce virtually all direct reflection. Matte surfaces, such as flat white paint, have a nearly complete diffuse reflection.
Pens typically have a mix of the two types. Wood grain, for example is primarily diffuse reflection. A glass-smooth finish, however, will produce direct reflection. Shiny metallic pen components (nosecones, centerbands, clips, and finials, for example) generally yield direct reflections. To consistently illuminate pens well, you need to understand how these reflections work and how they interact. That will determine where you position your lights, what kind of diffusers / reflectors you use, and how you can use polarizers and/or gobos to control glare.
  • Glare, as I have said before, is a strong direct reflection that washes out highlights or otherwise detracts from your pen photo. Sometimes (depending on the material, glare is polarized, sometimes it is not.
Sylvanite
Polarized glare, part 1
As I said above, sometimes direct reflection will polarize light. If unpolarized light strikes a non-conductive surface at the correct angle, then the surface can absorb the portion of the light with an axis of polarization perpendicular to its own static charge, and reflect only light with a polarization orientation parallel to the surface charge. This is what we call a polarized reflection.
Here are a couple of pen photographs exhibiting a polarized reflection. I deliberately placed the pen and one of the lights to produce a glare line that is polarized. I put a polarizing filter (CPL) on the camera lens. Both images are lit the same. The only difference is the angle at which the polarizing filter was rotated.
attachment.php
In the left photo, the polarizing filter was rotated parallel to the axis of polarization of the glare. Because they are aligned, the filter transmitted the glare undimmed. The human eye does not discriminate on polarization, so this is how the pen looked in person.
In the right photo, I rotated the CPL filter 90 degrees. Now it's polarization axis is perpendicular to that of the glare. As a result, the filter absorbed all that light - effectively removing almost all of the glare.
In both photos, the diffuse reflection off the wood, and the direct reflection off the metal components are unpolarized. Turning the polarizing filter from one orientation to the other did not change the intensity of those reflections.
I hope that makes sense so far,
Eric
Sylvanite
Polarized glare, part 2
A lesser known, less intuitive, but equally effective (if somewhat more expensive) technique is to polarize the light before it hits the pen, rather than after it reflects off. In both of the photos below, I've placed a photographic linear polarizing filter in between the light and the pen (instead of on the camera lens). You can see it in the upper right corner in each image (and its shadow over the top half of the upper barrel of the pen).
attachment.php
In the picture on the left, I positioned the filter so that its polarizing axis matches that of the glare. Other than cutting the amount of light reaching the pen barrel, it has little effect.
In the picture on the right, I rotated the filter 90 degrees, so that its axis of polarization is perpendicular to the polarization of the glare. Just like in my previous post, you can see that the glare in the shadow of the filter has been nearly eliminated.
How does this work? Well the explanation is very similar to that of a polarizing filter on the lens. When light strikes the pen barrel at this angle, the portion that is polarized parallel to the surface static charge is reflected (direct reflection) unchanged. The component with perpendicular polarization is absorbed. In the left photo, I pre-polarized the light so that there is no light polarized in the direction the surface absorbs. Therefore, the filter does nothing. In the right photo, the light is pre-polarized such that there is no light polarized in the axis that gets reflected. There is no direct reflection because all the light was polarized in the orientation that got absorbed.
The wood of the pen barrel produces diffuse reflection, which depolarizes the light. It remains visible whether or not the source light was polarized.
The reflections in the clip are also unchanged. That is because the clip is metallic (conductive). The direct reflection off the clip neither depolarizes nor repolarizes the source light. In the above two photos, the clip reflections are polarized in perpendicular directions, but that polarization is not visible in the photo because there was no polarizing filter on the camera lens. Just like the human eye, the camera's sensor does not discern light's polarity.
I used a small circular polarizing filter in this illustration. To use this technique effectively in studio photography, one would need a polarizing filter large enough to cover the entire light. Photo-grade polarizing film is available in sheets of suitable size, but they are more expensive than a typical lens filter.
I hope that was interesting,
Eric
farmer
NV
Polarization
It is a fact that not all polarized sunglasses are the same.
That's just like CPL and ND filters used in photography ...they are not all of the same quality and its very noticeable in photography...
And the fact is Not everyone who makes sun glasses just use linear polarized film by its self and some sunglass producers don't use linear polarized film in there ( polarized sunglasses ) .
Why would anyone want to conduct a what is to a very accurate test not use commercial linear polarized film that is what used in photography ?
Apples to apples .......................
When this thread is about the reflection issues in pen photography.
You started this thread teaching members about polarization ( polarized light and polarized reflection . And what its effects are in photo graphing pens,,, right ?
You went into using Linear polarized film and its effects .
And you have zero experience using linear polarized film in photography.
( what is up with that ) ?
And you seem very negative about using linear polarized film in photography when its used thousands of times every day by professional photographers.
Straight up, how did you come not to like using linear polarized film in photography when you have never tried it once in your life ?
You have disregard or turned a blind eye to polarization by reflection, transmission and scattering. Wiki Links
You pawned these laws off as well some times you get polarized reflection and some time you dont.
I have never read that !
I believe you twisted or took polarization by refraction out of context.
And what a camera see when using natural sun light, the light is partial polarized and that has been published over and over..
We are talking photography ? and not what the human eye sees .
Because it is also a published fact that humans dont see polarized light like most or like allot of other animals.... and you can include cameras in that list.
Regardless of what you know or you think you know you are not qualified to teach anyone about using linear polarized film in product or commercial photography ......... because you have zero experience .
Because of that and your total disregard to what i would consider the laws of polarization and i do have to thank you because i dont like learning things to debate anyone but I did learn.
4 laws that polarize light........
Polarization by
Transmission
Refraction
Reflection
Scattering.
Where are we, well I have been using linear polarized film in photography for about two years and i would expect that anyone wanting to teach people about polarization , reflection and glare and linear polarized film would have hands on experience... which you don' or at least not with LPF.
I don't like using using Florescent , can i base my opinion experience ( yes )
You don't like Cross polarization technic , can you base that opinion from your own experience ??????????? NO
I like most of your pictures and i think you have allot of experience offering members advise using a light tent and florescent lighting.
I dont know about the rest of your photography skills or technic , but i would guess that you would do a good if not a great job.
But if you have never used linear polarized film in photography at least you should drop your bias opinion.
