Newbie pouring
Yosemitesam
Atlanta Georgia
Purchased my products from Aluminite and did a pour yesterday.
Mixed A& B equally then added red dye and gold powder. Poured the minx into molds and noticed some of the powder floating on top. Placed into pressure pot
And was still there after it hardened. Is this normal or did I not mix well?
BSea
Little Rock, Arkansas
I mix the colors into part B before mixing in part A. That way I'm in no hurry to mix my colors. Be sure everything is completely dissolved before continuing. When I mix part A to part B, I mix each color for vigorously for 45 seconds minimum.
Hope this helps
endacoz
Brookfield, NY
Hope this helps
And you do a DANG GOOD job at it! Was turning some more of your pen blanks today .... I like they feeling they have when I am turning the.
Kendallqn
Phoenix, Az 85044
Depending on what, and how much of what, you mix in, it is normal to see some pearl on the top. Some will float a bit but the blank will still be fine when you cut into it if mixed well.
BSea
Hope this helps
Thanks Ethan, but they might have been blanks from Scott's wife. Lyn does a little over half of the PR blanks. I do the rest of the PR, and the alumilite. Regardless, we love seeing our blanks on other peoples pens.
hint hint
Fay Prozora
Port Angeles, Wa
I do the same thing. I mix my pigments to part B before I mix A and B together. I make sure the powdered stuff is mixed well before I pour. Good luck. Fay
