edstreet
I wanted to do a product review for this kit as opposed to the Jr Aaron here. since there is a few differences in them.
The Jr Aaron is manufactured by Dayacom and is sold in the US by Jon David Jones Signature Pen Supply. I have several kits that came in last week and put one with another dealer for presentation.
Here we have a Gent Jr dressed up in antique brass plating. Right down to the center band.
The nib on this one is a #5.5 size nib, the Aaron and the Antony is a #6 nib.
If you recall from the previous post the difference in the nib sizes.
#5 nibs: length: 2.5cm /shoulder width: 7mm /base width: 5mm /fits a 5mm feed
#5.5 nibs: length: 2.6cm /shoulder width: 7mm /base width: 5mm /fits a 5mm feed
#35 nibs (also known as #6): length: 3.5cm /shoulder width: 9mm /base width: 6.3mm /fits a 6.3mm feed
#5 and #5.5 both fit into the same housing, same feed, only difference is the #5.5 nib is longer
The tube size and screw threads is the same Gent Jr size.
Worth noting the antique look is selectively shadow highlighted in key areas. I do not know at this point what process is used for this plating however.
Also worth noting
This photo speaks volumes as for how pen kits can change over time.
Also worth noting
