Powder coating powder?
bloodhound
Acushnet , ma
Hello all. I'm sure there is a post here somewhere. But have spent the past few hour looking. Can someone point me in the direction of a link about how to use powder coating powder to color blanks with? I am a powder coater and am very interested here. Thanks in advance.
Just like any other powder when mixing. Just have to be careful not to use too much to make it too thick. Here are some threads.
http://www.penturners.org/forum/f13/call-marble-maybe-127080/
http://www.penturners.org/forum/f43/how-about-powder-coat-color-resin-788/
I do not know if those links work but here is the google search and you can read them for yourself.
http://www.penturners.org/forum/sea...owder+coating+powders+in+casting+blanks&sa=Go
NittanyLion
State College PA
My only suggestion is to mix, mix, and mix again. I fabricated a little beater out of a brass tube for my drill press and mix it In small cups. Black requires extra mixing. Hope this helps.
79spitfire
Nevada
Can't really emphasize how much you have to mix. The powder will hang onto it self and try to form little dry centered lumps that will spring out at you later when you try to do anything with the finished blank, leaving a small funky crater.
