"The Stempunk Collection" latest member
See more from Si90
Si90
Doncaster, UK
Here is the latest addition to the collection. It may seam familiar to some as it's based on one of my earlier efforts in the collection which I have never put up for sale. Built around 3 glass tubes and aged in my usual way.
As always thanks for looking, until next time.
OZturner
Sydney. NSW. Australia
Congratulations Simon,
You have taken your Steampunk Pens, to yet another degree.
Beyond the scope of mere mortals, to the level of Jules Verne, and Dr Who.
This is Steampunk Functional Art, not only is the "Pen Out Of This World" with regard, to the Concept, Design, Functional Adornments, Attention, Finish and Patina.
But it is also exemplified by the beauty and attention you have applied to design and detail of your case.
With regard to your pens, there is really only One Question - What's Next.
I wait in Anticipation of again being Amazed.
Brian.
mark james
IAP Collection, Curator
Medina, Ohio
Incredible Art Simon! The complexity and imagination that goes into your work is amazing! Very cool.
I just received 1 mm threaded rods and nuts :eek:. Now I have to get a magnifying glass to see them! These pens really need to be seen in person to appreciate how complex these fittings are to work with in miniature.
Now I do appreciate your work more! :wink:
mark james
Medina, Ohio
Simon,
I am entered in the September Steampunk exchange and I'm trying to use them for that. So far I'm trying to turn 4 aluminum rings to circle a pen tube (2 beveled on the ends, 2 spaced in the between), do a foil cover for the tube, and have 3-5 rods and nuts going through the 2 rings in the center, spaced about 1"
I got the aluminum turned fine,I think it is 2.5 MM thick sheeting, but they are 2.5 mm from ID to OD, and drilling a 1mm hole with my equipment is a challenge. As I broke one drill bit, then drilled the hole through the side of one of the rings, my son learned a few new words.
But I'm having fun.
Oh, and when the blank is done I will cast it in Alumilite... So I'd better make 2-3 blanks to be sure I get one right !
Si90
Doncaster, UK
Mark, I've found drilling at those sizes you are best doing it by hand. Every machine/drill press/drill I tried even on its lowest setting is way too aggressive.
I also break my fine drills to shorten them so that it can go further into the chuck which eliminates the drill flex which in turn reduces breakages. I use drills right down to 0.3mm and drill by hand with a pin vice.
I have repeatably and successfully drilled by hand a 0.5mm holes down the centre of a 1mm aluminium rod to a depth of 10mm, you just have to take it really slow.
Looking forward to you Pith Pen, you never know I might even get drawn to receive or send to you :)
mark james
Medina, Ohio
Not only do you use machines... you ARE a machine :eek:.
HMnnnnnn, maybe a BORG themed pen...
Marko50
Orem, UT
Jules Verne like!
Geezo-Peezo, Holy Moley Simon!:eek: This has Jules Verne written all over it! Once again, beautiful work. You're an inspiration.
I'm gonna have to go rent "20,000 Leagues Under the Sea" for my Labor Day Weekend viewing pleasure and see if I can get some inspiration for this months Steampunk PITH!
plano_harry
Plano, TX 75093
Love the design. The spring filler is really cool, if that is what I am seeing. You haven't told us how many hours go into the actual construction. Must be a lot!
Si90
Doncaster, UK
The filler is just a standard twist filler that I added the embellishments too, it works in the standard way. As regards number of hours, it's difficult to say. I made this over the course of 4 or 5 days, maybe 4 or 5 hours a day. There is a lot of stop starting. I don't have a fixed design when I start, just a basic idea so many parts get made and rejected, pauses occure while it is being pickled between brazing steps etc. I had intended for this pen to have considerably more tubes, pipes and fittings but in the end less was actually more in this case.
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
I think the fact that you of all people have spelled 'Steampunk' wrong means you should just send it over to North Wales, I know someone that will take care of it for you as penance......:rolleyes:
Si90
Doncaster, UK
:eek: Oh man that's outrageous, never even noticed.
I assume it would be addressed to A Skip in Wales. Unfortunately it's on it's way across the pond, might even be passing over your head as we speak and I didn't fit it with a parachute. :rolleyes:
mark james
Medina, Ohio
Well Steven... If there is a penturners meeting on your side of the pond... There may just be a few pens available that you could look at... (An e-mail address will produce pictures of the first 10)...:rolleyes:
Best Regards, Mark
mark james
Medina, Ohio
OK... It took me about 30 minutes to find it... Sneaky, sneaky...:glasses-nerdy: But you're correct!
Dale Lynch
Hastings,NE
Alright,alright,enough messin around.When are you gonna make one that actually produces steam.Lust kidding,it's magnificent.
