Got Blue Yet??!?!
rblakemore
Friendswood, Tx
...Not ... well, sort of, maybe.
This is a follow up to my thread of 7/25. And, I am also a biologist by education, so I am also a scientist and like lots of experimentation. There are a bunch of pictures attached.
So, I was not satisfied with my first results of blue alumilite dye in stabilizing resin. As soon as I get more Cactus Juice, I will try again.
In the meantime, I have tried using dye directly on the wood, in this case a piece of clear stabilized spalted figured maple. Reading older threads, I chose Jacquard IDye (Jacquard also makes mica dust used in casting and a dye others have used) which I searched for and found at a local JoAnn's Fabrics (a favorite place of my wife). I first mixed with a little bit of 70% Isopropyl Alcohol and it did not mix well at well. Adding water it dissolved quickly. Reading the instructions (sort of recommended), hot water is used. Adding hot water and then soaking the sample blanks, I used a short plastic rod with treated cotton fibers (aka Q-Tip) and coated the two sample blanks; see pictures 1 and 2. The maple looked a dark blue, success, maybe??
When I cut one blank, notice that there was no penetration by the blue dye. See pictures 3 and 4. I went ahead, glued a tube, and turned. The wood was a dingy, gray-blue, not much different than the spalted maple without dye. See picture 5.
I dyed the blank on the lathe sanded and dyed again, and then made a CA finish. See pictures 6 and 7.
And, the final pen is in picture 8. This is a Timberbits Sierra upgrade in Ti and Gold.
I offer this is successful and I achieved a blue, a little dark perhaps; but, this proves that this form of dyeing for coloring blanks does work.
Your thoughts please??
Jim Burr
Banned
Reno, Nv
I usually dye when the blank is about 1/32" proud of final thickness. Using Analine(?) has worked for me.
CrimsonKeel
Royal oak, MI
some analine dyes are on my amazon wish lis for my next order to try them out.
Is it hard to get a decent color blend? Ive seen some pictures of a guy who makes calligraphy pens and his analine dye jobs are phenominal
BSea
Little Rock, Arkansas
Are you saying you tried to dye a piece of maple that had been stabilized? If so, then that would explain a lot. A stabilized piece of wood would soak up almost no dye.
If that's not the case, then probably you didn't use enough dye with the cactus juice. I use about 1/2 of a bottle for a quart, and that worked pretty well on some curly maple. It turned the wood a medium blue even though the liquid was really dark opaque blue.
sschering
Eugene, OR
Exactly how I did my bash pen and a few others. I love the results.
You can also use WTF to remove dye and manage the depth of color a bit.
107729d1390181561-stabilized-dyed-spalted-hackberry-jr-get-fountain-rhodium-1_imgp6382__2_.jpg
