Need Help. Trying to repair a pen made by a penmaker that has passed away.
rodtod11
Hello,
I've been asked to repair this pen by the family. They want to give it to his son. I Cant seem to find a transmission for it. It measures 7mm approx. I was able to remove it and with the right transmission I could have to repaired and returned to the family.
ed4copies
Local Chapter Manager
Racine, WI, USA.
It looks like it would take a standard 7 mm "cross type" transmission. That is not exactly what you show, but the dimensions say it should work. Steal it from a slimline kit.
Hope this helps,
ED
rodtod11
Thanks, I tried that and it is too small. The slimline kit measures 6.35 mm. This tranny is 6.93. The Slimline tranny just falls through the tube. I just do not remember ever seeing a kit out there like this one. Looks like a Summit from Rockler but the tube measures 6.90 mm and the Slimline measures 6.20.
ed4copies
Racine, WI, USA.
Can you cut a 7mm tube about an inch long and insert it into the existing tube (call it a spacer to make your standard transmission fit)!
Jim Burr
Banned
Reno, Nv
After reading everything...you've got several different dimensions floating around...slim at 6.35 and 6.20...needing a 6.9. What is the exact diameter of the tranny you need?
rodtod11
Sorry about that. I was measuring the Slimline tube, old tranny, tube I.D. of the pen I am repairing. The tranny I need has to go into a tube with an I.D. of 6.9 mm
duncsuss
Wilmington, MA
I've got a pen with a transmission that measures 6.91mm (measured as close to the lower barrel as I can get.) It's a pen I was given and means nothing to me -- if you'd like, I'll knock the tranny out of the barrel and you can have it.
rodtod11
Wow! Thank You ! That would be great! My e-mail is rodtod11@gmail.com. Thank You!
duncsuss
Wilmington, MA
Rod, I'll try to get that in the mail to you tomorrow. I might get distracted, as I just found out my car radiator needs to be replaced -- hoping that I noticed it before any more serious damage ensued.
duncsuss
Wilmington, MA
Wow! Thank You ! That would be great! My e-mail is ...
email sent ...
Duncan,
It works!!!! I cant thank you enough! I called the family and they were very happy and said thank you also! I'm going to pack this up and ship it off to them. Now they can put together that packet for this guys son. Again, Thank You!
Excellent -- glad I was able to help. It's probably the most worthwhile thing a freebie pen has done.
