latest kitless pen
See more from jj9ball
jj9ball
Norfolk, NE
Here is another kitless pen. I tried using a plain color on the cap to hopefully calm down an otherwise wild blank. I'd be interested to know if anyone thinks it did or didn't work. Pen is 6 1/2" long closed and pen body is around 5 1/2" long alone. Body to cap has 14mm threads and section to body has 9mm X .75 threads. Has a fine bock nib. Comments always welcome.
Jeff.
MarkD
Sayre, PA
Personally, I would have matched the cap to the body. Then again, if the front section was black I might have used a black cap. Just my 2 cents :biggrin:
Brooks803
Aiken, South Carolina
Personally I think a matching cap finial would look better and then use a black section. Or if you did the same black end on the body of the pen. I totally agree the blank needed a break. 6 1/2" is pretty long. Does the cap post? I like your shape and how well it flows. The recessed clip is perfect. Well done.
Jim Burr
Banned
Reno, Nv
I'm in the matching cap and section crowd. I see your point in doing the cap...looks good, but it seems a little lost. Over all...well done!!
jj9ball
Norfolk, NE
Thank you everyone for your feedback. I have a confession. In the middle of making the pen I thought "I should add some solid black somewere". At that point I was already done turning the body, section, and all but the top of the cap. So the only thing I could add black to was the top of the cap. Now for the next pen I will definitely make some of those plans a little sooner. Thanks again for the feedback and listening to an airheaded penturner:glasses-nerdy:
jj9ball
Norfolk, NE
The cap doesn't post. I got a little too carried away on letting the metal lathe make the body straight. When I went to clean up the back and finish it the body was already too small to hold the cap on the back.... live and learn. I gotta learn how to plan my pen builds a little better. This is getting ridiculous. Thanks for the feedback.
lwalper
Lancaster, TN
How do you get the inside of the barrel (and cap) smooth? Mine come out with drill bit scoring -- all cloudy inside. Do you polish the inside?
BTW -- nice pen. I like the black finial.
jj9ball
Norfolk, NE
Thanks. I don't polish the inside but I do use a lubricant (cooking spray) when I drill the long holes for the body and cap. For the cap I also make sure to drill the hold in about 3 steps (center drill, 9mm, 13.3mm). This keeps heat down, along with the lubricant, and it also keeps the drill bits flutes from jamming up and inadvertently boring my hole bigger. When I polish I do a little on the inside of the cap because I feel like it makes the threads work better (that could totally be in my head too). I hope this helps thanks for the feedback.
OZturner
Sydney. NSW. Australia
What a Pen, Jeff, That is one that will really "Stand Out from the Crowd"
Considering where you were at, when you decided to "Tone it Down".
I don't think you could have done any better.
You have Great Lines, Terrific Proportions, which have given you a Magnificent Profile.
Excellent Fit and Finish.
Congratulations,
Brian.
