tbc pen busings
ajthunem
littleton, co
where can i find "turn between center" bushings for a PSI bolt action kit??
any IAP vendors sell them???
Also short of that I would like some opinions on the "EASIEST" ( and i know that term is subjective) and most accurate pen mandrel on the market.
ed4copies
Local Chapter Manager
Racine, WI, USA.
If you use a mandersl, I would recommend an adjustable length mandrel. There are many available, the major difference being that some require two wrenches to loosen the collet, others are designed to do this by hand.
Charlie69
You probably know this but it's worth mentioning... bushings are completely unnecessary for tbc. I use the stock bushings until the o.d. is close then work off the brass tubes. If i was a production turner i would use high quality bushings because it would be quicker using them.
