edstreet
Sounds like a megga poll is in order that includes all the pen kits.
Guy's and Gal's I will be sending Constance a list with sizes this evening so if anyone has the size for the slim, the bushing and the shaft let me know.
Weather providing and the like ...
You just gotta move farther north Ed.Weather providing and the like ...
I'll buy them either way. The ones I got from JohnnyCNC years ago are getting tired.
I would prefer them with 7mm holes, but I can drill holes in the few that I use that way. GOOD JOB! It's about time we have these back in the market place!
Has Johnny stopped making them since his mishap. .??? Linv
Here are the bushing I will be ordering, if you have any that you think would be added to this list let me know here:
Sierra series,Elegant beauty,Aero,Art deco,Artist Sketch pencil,Bullet Cartridge twist, Bullet Cartridge Click,Cigar twist,Baron-Sodona,Zen,Vail,Jr series from CSUSA, Jr. Majestic, Full sized Gent-Statesman, full sized Majestic.
Does this include the Sierra Vista/Wall Street III?
Charlie_W;1629590 Does this include the Sierra Vista/Wall Street III?[/quote said:Yes, it would
Roy, will the 7mm hole variant ALSO have the 60 deg? If so, then that surely would be the best option?
I would guess that if they don't have a through hole then the 60 deg variant would be made using a centre drill, ( leaving the pilot dimple) thus avoiding the tip of the centre from possibly bottoming out in the hole?
What material are you going to make them with?
It's not clear to me why, I've used both and both work equally well. While the drill through will have a little less gripping area, surely no one is thinking that's going to make a difference in the turning? Or in the amount of pressure needed for a good safe hold by the live center?Skippy, yes the 7MM hole also has a 60 degree recess, and frankly that's the way I would prefer but in the voting it's almost 3 to one with now drill through and just a 60 degree recess so we will do what the majority wants.
The 'hole' removes approximately HALF the weight of the bushing. Also removes at least half, possibly more, structure strength of the bushing from outside forces. The 'hole' also removes the surface contact to the live center and dead center.
For some materials this may be workable but I can see a need for heftier work loads there could be problems.
LeRoy I totally agree that the through hole would not effect the turning as there is enough meat that the 60 degree recess is more than actually needed, but as been often said "When in Rome do as the Romans ask us to do" or something like that. :wink: BTW as to why I would prefer the through hole, as a supplier I have customers that want accuracy in a better bushing that most imported bushing but do not TBC so this gives them the best of two worlds and when or if they do decide to try TBC they are tooled up with the proper bushings.
What does the hole gain though for those turning between center?
The extra weight and grip surface may or may not make a real difference but I don't see a thing to be gained by having the hole through for those turning between centers
Personally I like overkill beefier the better!
That way we can serve both the people who want to use a mandrel and the once who just turn between centers. Kill two birds with one stone:biggrin:
Of course that is exactly what one would expect the point of the live center has a hole to go into and it will go in farther than if you have just a tiny point hole as John Goodin's do.1. I already have most of the bushings I need for the time being - I will prob still buy a couple sets.
2. In the interest of others, I will still buy with the hole, but I prefer no hole and would still vote that way for what I like most.
For comparison, here are Jr. Series bushings. One is Constants, the other Johnny's.
Interestingly, with the hole, the bushing contacts the center higher with the hole. Hopefully the picture show how much and where is the contact area. (This is not to prove any point, just an FYI.
You are right. The live center is a cone - going into a slightly less than 7mm hole with a taper machined at the entrance, the live center has to go in until the diameter of the cone is equal to the diameter of the hole which should be when the cone contacts the tapered edge of the hole.For comparison, here are Jr. Series bushings. One is Constants, the other Johnny's.
Well of course it will sit higher, or farther into, the 60 degree center. The hole is larger. It has nothing to do with the taper of the hole.
If you look closely at the one from John Goodin, it is drilled with a center bit. That is to make sure the point of the center never bottoms out.
I suspect that the ones made with the mandrel hole were purposely drilled deeper to give the extra contact surface.
Actually Ed it makes no big difference as the 30% who voted a thru hole did for a reason, and the 70% who voted no thru hole did it because that's what they are used to and the way I framed the poll left them no other choice. As a vendor I think 99% of the voters who voted no thru hole would still buy them and all 30% who voted thru hole would also buy them, so the sound business decision would be to accommodate all at this point. We are going to keep the cost down as much as possible so making one style at this time would accommodate the most customers and help us have the lowest final price available. As always appreciate your input.
